And finally, Wookie's 82 begins !
- blackozvet
Re: And finally, Wookie's 82 begins !
28 Sep 2022 07:10It all started as a Z1 tail piece conversion
08 Oct 2022 11:58
I haven't touched the bike for a couple of weeks as last weekend I took Mrs Wookie to London. 3 years ago I bought concert tickets for her birthday but it was cancelled due to Covid so last weekend she got her wish to see Andrea Bocelli (not exactly wild rock gig but excellent just the same a I think she might be too classy for me)
So today I started on the other side panel ( I Promise it will get more interesting soon) what a PITA that turned out to be, the first one wasn't too bad to do but the right hand side is an aftermarket panel which is a different plastic ( thicker, harder and not ABS) it reacts to heat differently, the curvatures are a little off and it resists the "hot rivets" to make the joins but we have got there in the end (I have left it for the glue to set now and will start sanding in the morning
09 Oct 2022 10:17
So I now have a matched pair of side panels, I have put the flange in for the lower mounts (will trim once I have decided where the mounts will be) feeling good
- Jonas_Z1000j
09 Oct 2022 11:38
Very nice!
I guess you have the original mounts left and will reallocate those? Or will you fabricate new ones?
One of mine have broken off and is missing, I have been poundering if I should fabricate something or get a new panel..maybe you have some ideas for this?
Z1000 J2 -82 not so running restoration object anymore
Z900RS -21 Green/Yellow
09 Oct 2022 11:53 - 09 Oct 2022 12:16I need to fabricate almost everything on this build, the original frame mounts are gone and the panels are a totally different shape now. I will pick up the bottom mounts from the extra tubes I put in to brace the frame for the mono-shock conversionVery nice!
Have you got the piece that broke off your panel ?
Edit: just saw that it is missing maybe you could find what you need on a different panel (or just bite the bullet and buy new) I am only going to all this hassle because I can't buy panels that would fit the way I want with the frame mods and one- off seat
Last edit: 09 Oct 2022 12:16 by Wookie58.
18 Oct 2022 14:30
The following user(s) said Thank You: Street Fighter LTD, slayer61, Nerdy
- blackozvet
18 Oct 2022 21:28She will realise when you start spending endless hours in the garage making small intricate things !
1973 Z1 900 Kawasaki
22 Oct 2022 10:52 - 22 Oct 2022 10:52
Happy to report that the saga of the sidepanels is drawing to a close, got the mounts sorted today so just a bit of fine tuning and they will be ready for bodyworking
Last edit: 22 Oct 2022 10:52 by Wookie58.
The following user(s) said Thank You: blackozvet
22 Oct 2022 18:44
Go Wookie Go !!!!!
30 Oct 2022 11:45 - 30 Oct 2022 13:13
More thrashing on plastics this weekend, have got the mods done on the rear inner fender (to clearance other components) just needs tidying up and trimming now once the bonding etc has had time to set properly. I have included a pic of an original for those not familiar with how it used to look. Also started bending a sheet of ABS to make the finishing panel that will replace the original fender
Last edit: 30 Oct 2022 13:13 by Wookie58.
- Wheelhop
30 Oct 2022 16:01Looks like you have a little room under there for a bottle of Nitrous!
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
