And finally, Wookie's 82 begins !
  • calum
  • calum's Avatar
Re: And finally, Wookie's 82 begins !
25 Sep 2022 01:37
#874476
Did you make any progress on your days off, or did the daily driver eat up all your free time?
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Moderator
25 Sep 2022 02:44
#874481
Am working on the side panels currently, will update later
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
25 Sep 2022 03:54
#874484
It will get rear interesting real quick when they are done and the seat has a skin on it.
  • Wookie58
  • Moderator
25 Sep 2022 09:07 - 25 Sep 2022 09:09
#874499
And so to the fruit of today's labours   I have finished re-shaping the left side panel so it now fits properly in it's new home and is pulled in a little tighter to narrow the old girl around the waist ( every little helps when you have short legs) I basically cut into three main parts and then added or removed material where necc so it still looks like a KZ panel just a little different (15mm longer at the front, 35mm longer at the back and 25mm shallower in the depth) I have included a before and after comparison with the right side. If you don't have one of these "hot rivet" guns you should get one, even before it was glued it was solid with just the rivets (with plastics getting harder to come by most would be repairable using this method)
I have then painted over all the joints from the back with "gloop" ( scraps of ABS plastic disolved in acetone to make a paste) the acetone eats into the surface of the plastic to make a permanent bond ( it's like adding another layer of plastic) just needs a light skim of bondo and some mounts now
Last edit: 25 Sep 2022 09:09 by Wookie58.
The following user(s) said Thank You: calum, howardhb
  • kzstreetfighter71
25 Sep 2022 10:40
#874508
The definition of a Frankenstein bike.
  • Wookie58
  • Moderator
25 Sep 2022 11:16
#874513
Is that a good thing
The following user(s) said Thank You: kzstreetfighter71
  • kzstreetfighter71
25 Sep 2022 12:23
#874515
Hell ya it is, creating something new from the old is the way to go.
The following user(s) said Thank You: Street Fighter LTD, calum, Wookie58
  • calum
  • calum's Avatar
25 Sep 2022 12:51
#874517
Nice work, that's something I don't think I'll ever have a go at - too much patience required!
The following user(s) said Thank You: kzstreetfighter71, Wookie58
  • Wookie58
  • Moderator
25 Sep 2022 14:41
#874523
I did say I wanted to use as many OE parts as possible, I never promised to leave them stock though
  • DoctoRot
  • DoctoRot's Avatar
25 Sep 2022 21:48
#874541
Extremely nice work. We need pics of them of the bike!
  • Wookie58
  • Moderator
26 Sep 2022 10:15
#874591
Thanks Doc, attached as requested. It's certainly on a journey and there isn't much "Ltd" left now
  • kzstreetfighter71
26 Sep 2022 10:37 - 26 Sep 2022 10:37
#874596
They nearly have a Z1 look to them, nice one.
Last edit: 26 Sep 2022 10:37 by kzstreetfighter71.
