1979 KZ650B Streamlined Restomod
  • Oysteinaar
  • Oysteinaar's Avatar Topic Author
Re: 1979 KZ650B Streamlined Restomod
25 Feb 2022 01:20 - 25 Feb 2022 01:21
#862901
Warren3200gt: I might have to put the bike through an inspection before I can get plates on it, so I think I'll hold on to the parts I have removed untill then, just to be sure. (Will be around april-may I hope!) I love the look of the new rear fender, so if it's all good, and you're still interested then, the rear fender is yours
Kawasaki KZ650 1979
Last edit: 25 Feb 2022 01:21 by Oysteinaar.
The following user(s) said Thank You: Warren3200gt
  • Warren3200gt
  • Warren3200gt's Avatar
25 Feb 2022 01:30
#862902
Great, no rush, just confirming my interest.
  • Oysteinaar
25 Feb 2022 11:50
#862915
Spent a good while cleaning carbs today, turned out good by my standards. I'm not into the "super-clean polished look" I like my parts clean of course, but prefer a little patina.
Before:
After:
Also cleaned them inside and switched to 15 pilots and 110 mains + new gaskets, should be fine with the exhaust I'm running + henry abe airbox. If not I also have 17,5 pilots and 107,5 mains laying around.
Kawasaki KZ650 1979
  • Oysteinaar
27 Feb 2022 13:59 - 27 Feb 2022 14:04
#862984
I bought a new cover for the right side, the one that was on the bike when I bought it came from a ltd or something. Fixed it up, and it's now ready for paint.
Kawasaki KZ650 1979
Last edit: 27 Feb 2022 14:04 by Oysteinaar.
  • Oysteinaar
27 Feb 2022 14:03
#862985
The gas tank had a little bit of rust/rustflakes in it. So I left it with a vinegar essence/water mix overnight, cleaned up pretty good, and doesn't have any leaks. It's currently drying. I will add some fuel with a little oil in it when dry, to "coat" the inside. Afterwards it will be prepped for paint as well.
Kawasaki KZ650 1979
  • Oysteinaar
12 Apr 2022 13:54 - 12 Apr 2022 13:59
#865304
I'm finally home for easter, aaaaaanaaaaaand it's time for painting!
Spent the whole day today prepping parts, and put on some etch primer on the metal parts + plastic primer on plastic parts.
As stated before, I'm going for a more modern look on the bike, so the chrome had to go.
Black paint on.
Detailed the emblems, and put on 2 layers of clearcoat
Fitted some pre-oiled filter material in the henry abe filter, and mounted both the carbs and filter on the bike.
note: taped off the ends of the filter-"grille" to avoid problems with crosswind/rain which is a normal issue with podfilters.
The tankset alone will have 6 different types of primer/paint on it. Hope it turns out allright
Kawasaki KZ650 1979
Last edit: 12 Apr 2022 13:59 by Oysteinaar.
  • 750 R1
  • 750 R1's Avatar
12 Apr 2022 15:59
#865313
The bread box doesn't suffer side winds as bad as pods, reason being, it has velocity stacks built in..
  • Oysteinaar
12 Apr 2022 23:08
#865326
It doesnt suffer from side wind quite as bad as pods, but it's still more prone to it than with the stock airbox.
Kawasaki KZ650 1979
  • Oysteinaar
13 Apr 2022 01:25 - 13 Apr 2022 01:29
#865327
Found a better picture from the painting process:
Kawasaki KZ650 1979
Last edit: 13 Apr 2022 01:29 by Oysteinaar.
  • 750 R1
  • 750 R1's Avatar
13 Apr 2022 14:40
#865367
The difference being that ALL the air going into the engine is drawn through the velocity stacks, so its a different scenario to just normal pods...
  • Oysteinaar
14 Apr 2022 08:36
#865417
Finished.
Now I only have to shorten the front fender and get some paint on it + assemble the front forks with some pvc tubing to stiffen it up.
The tankset and everything else will be mounted in may/june.
Kawasaki KZ650 1979
  • Oysteinaar
14 Apr 2022 08:37
#865418
2 layers of fresh clearcoat this morning
Kawasaki KZ650 1979
