KZ1000A1 Spare Parts Project
  • calum
  • calum's Avatar Topic Author
Re: KZ1000A1 Spare Parts Project
13 Nov 2022 14:31
#876775
Thanks. I've seen that photo somewhere before but dismissed it as I didn't think the side cover would still go on. Guess I should have checked ;)
  • Mikaw
  • Mikaw's Avatar
13 Nov 2022 14:52 - 13 Nov 2022 14:56
#876779
Here’s my 900 project before tear down. Same routing
Last edit: 13 Nov 2022 14:56 by Mikaw.
  • calum
29 Nov 2022 09:22
#877302
I just picked up some used parts on ebay - a tool try and a drawer for the tail section. Does anyone know how to tell if they are original or replica parts? Not really that important but it would be nice to know for when I tally up all the non-original parts when this thing is back together.
  • Wheelhop
  • Wheelhop's Avatar
29 Nov 2022 09:49
#877304
I don't know much but I do know that the document trays were tailored to specific model years and sub-models like Z1, KZ, or LTD.
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
  • calum
29 Nov 2022 12:26
#877311
The document tray has a picture of a KZ1000A1 or A2 on it, so if it is original it should be right...
The following user(s) said Thank You: Wheelhop
  • BCScott
  • BCScott's Avatar
29 Nov 2022 14:47 - 29 Nov 2022 14:48
#877320
Looks original to me. Here's mine:
All of the dimples in the trays look identical.
Back in the saddle and loving it! KZ1000A1
Last edit: 29 Nov 2022 14:48 by BCScott.
  • calum
30 Nov 2022 04:03
#877334
Thanks. The thing that got me wondering was the tool tray being asymmetrical, but it looks like that is normal (the bit at the front is slightly off to the left).
  • hardrockminer
  • hardrockminer's Avatar
30 Nov 2022 04:43
#877335
The main harness runs around the left side of the headstock and attaches to the left frame rail, underneath.  The Y in the harness sits roughly right behind the coils.  I used to have photos of how it goes, but I can't find the correct ones.
If your question on the frame brace refers to the one near the end of the tank, it's used to tuck away the ends of the carb vent holes.
  • calum
30 Nov 2022 13:36 - 30 Nov 2022 22:08
#877365
Yeah, that was what I meant. There is also a nut welded to the plate - any idea what screws into that?
Next question: My kickstarter has about 10mm of play at the end. This is due to a pretty sloppy fit between the two parts of the kicker. Is this normal or did my chrome guys go a bit crazy with the belt sander?
Video:    1drv.ms/v/s!Ave4Y68f_qkhwJ9-UNmRKSwxvrn7zw?e=LzgEg7
Last edit: 30 Nov 2022 22:08 by calum.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
30 Nov 2022 18:18
#877377
Looks normal to me but i have to ask, how often did you have to use the "cosmetic" kicker?
Wecke keine schlafende Hunde, lass es so, man kann Perfektion auch übertreiben!
  • calum
30 Nov 2022 22:07 - 30 Nov 2022 22:08
#877381
Thanks. It was more a question of the work the guys had done - I didn't look to closely at it before I took it apart and dropped the parts off to be plated. Now I'll just assume it was like that beforehand...
  • hardrockminer
01 Dec 2022 05:22
#877383
The kicker has an adjuster screw I think.
No idea what screws into that nut.  None of my bikes has one.
