KZ1000A1 Spare Parts Project
- BCScott
Re: KZ1000A1 Spare Parts Project
06 Nov 2022 09:09
My nut has always been on the right side, too. Where did you find the exhaust? It looks pristine. The build looks terrific!
Back in the saddle and loving it! KZ1000A1
The following user(s) said Thank You: Mikaw, calum
- calum
06 Nov 2022 09:18
Got the exhaust from a guy that deals with KZ's here in Germany. Every now and then someone comes in and swaps one out for a 4-1. It's not perfect but it's pretty good - the right hand side is really nice except for a couple of spots on downpipe #4. The left side is pretty good, I'd like to get it re-chromed but the local guy will only do mufflers with the baffles removed (not an option on the KZ1000 4-2 exhaust). It's good enough though, so I should probably just leave well enough alone...
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
- calum
06 Nov 2022 10:52 - 06 Nov 2022 10:53
I took all of the wiring off the shelf today. Looks like it should be OK to reuse - I'll check everything when I re-wrap the main loom. After sorting though everything I have a few questions for you guys:
- I can't find this part - what is it and do I need it? www.cmsnl.com/kawasaki-kz1000a1-1977-can...or-voltage_21066026/
- There is a long black wire coming off the rectifier. I know this goes to ground, but where does it usually get screwed on? Directly to battery negative?
- The brake light failure indicator seems to be connected to the main harness somewhere under the tank. Does anybody know where the mounting plate for this goes?
- The flasher relay has three pins. I am assuming this is a combination hazard/indicator relay with a shared positive. The problem is that there are four connectors coming off the harness (as expected with two seperate relays). The hazard relay wires are in the branch for the rear brake light switch and engine ground, the flasher relay wires come off the back section of the harness (near the connector for the tail section). I'm thinking I'll just get two standard relays as I'm pretty sure that was stock. I know that one mounts next to the fuse box, does anyone know where the second one goes?
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
Last edit: 06 Nov 2022 10:53 by calum.
06 Nov 2022 17:00I was wondering the same. To me that is the sexiest OEM exhaust KHI built. I’d love to find one in that nice of shape.My nut has always been on the right side, too. Where did you find the exhaust? It looks pristine. The build looks terrific!
07 Nov 2022 02:29
07 Nov 2022 17:46
07 Nov 2022 17:52
The shorter brown and blue go to the rear brake light switch.
- calum
07 Nov 2022 21:34 - 07 Nov 2022 21:35
Thanks guys, I had a look in the book yesterday after scirocco's post and saw the flasher relay location. Thanks for the info on the rectifier - will see how that lines up tomorrow. Was all good on the rest, except for that wierd voltage regulator and the location of the green resistor for the headlight circuit (although I'm pretty sure it gets bolted to the left hand coil bracket).
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
Last edit: 07 Nov 2022 21:35 by calum.
- calum
13 Nov 2022 12:05
Got some new cam bearings and was going to put them in. They were supposed to be original Kawasaki parts but don't look the part. There a 16 shrink-wrapped together. They have STD stamped on one side and 18A on the other - AFAIK the stack bearing shells aren't stamped...
I cleaned up and wrapped the main harness today and managed to get most of the electrics in. Need some flasher relays and a few bits of hardware to get it finished up, will also replace the ground and starter cables.
Does anyone know how the main harness is usually routed under the tank? What goes through the hole in the bracing?
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
13 Nov 2022 12:17
- calum
13 Nov 2022 12:29
Yeah, it's PET fleece stuff from Tesa. Holds up pretty well - has been under the hood of the mini for a few years and looks as good as new.
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
13 Nov 2022 14:04 - 13 Nov 2022 14:08
The harness goes under the brace where the tank elastic goes. Then wraps around the frame to the outside to get to the relay plate. The oval hole in the center brace is for the carb vent tubes
stock photo pulled from the internet
Last edit: 13 Nov 2022 14:08 by Mikaw.
