1977 KZ1000 Restomod
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
Re: 1977 KZ1000 Restomod
20 Jun 2022 01:10
#869088
Super clean work mate.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
20 Jun 2022 06:09
#869093
Im Loving it !!!!!!!!!!!
  • Mikaw
  • Mikaw's Avatar
20 Jun 2022 08:51
#869105
Excellent. You adopting. Your an awesome dad!
  • Buzz Nichols
  • Buzz Nichols's Avatar
20 Jun 2022 09:39
#869108
Absolutely gorgeous.
1978 KZ1000 LTD
  • calum
  • calum's Avatar Topic Author
20 Jun 2022 14:54
#869119
Thanks guys! It's been a long haul but it looks like it will finally be on the road this summer. We're pretty happy with how it turned out.
Only downside is that my son still has 6 months on his A2 license so we need to knock it down to 48HP for a while. Next season we can put the Zephyr to the test, though :) He may even be heading out for a ride only to find out that his bike has been "borrowed" ;)
  • calum
27 Jun 2022 22:21
#869449
Ready to clean up the transmission. One of the circlips didn't survive the disassembly so need to wait for a new one before I can put it back together.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
27 Jun 2022 23:24
#869451
Hey Calum, are you sure you have enough things "on the go" I guess with the Zephyr done you need something else to keep You busy
  • calum
28 Jun 2022 05:11
#869461
I'm just hoping at least one of these bikes is done before the wife's mini goes back in the garage to have the bottom-end and clutch done
  • calum
03 Jul 2022 14:09 - 03 Jul 2022 14:11
#869816
I would like to make a video of the final assembly of this build - when all the parts are done and everything has been painted. I figured it should include the engine build. The crank is already in but I filmed the assembly of the gears today. Will probably have to cut some content out or the final cut will be an hour long!!
I need to work on my camera angles ;)
Last edit: 03 Jul 2022 14:11 by calum.
The following user(s) said Thank You: DOHC, BCScott, Wookie58
  • Mikaw
  • Mikaw's Avatar
03 Jul 2022 14:29
#869818
Well done.
  • Rick H.
  • Rick H.'s Avatar
04 Jul 2022 09:17
#869847
Great idea Calum!!
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • calum
16 Jul 2022 12:45
#870457
I was getting all the parts together for the bottom end today. I have a MK2 alternator cover with a MK2 (or similar) stator. I got the stator with an adapter plate for the standard A1 cover (see the pic below) and a rotor from a different model. The rotor looks like it could be from a 750 (E1, H1, ...). It fits on the taper of the KZ1000A1 crank. Does anyone know which later model you can take the alternator from for an A1 if you just swap out the cover?
Adapter plate:
Here's a pic of the conversion kit (I picked it up cheap on ebay but I'm pretty sure it's this kit):
