Turbo for my KZ1000
  • zed1015
  • zed1015's Avatar
Re: Turbo for my KZ1000
13 Jul 2020 09:16
#830554
Nessism wrote: All I can say is WOW! I didn't know over the top exhaust routing was even a thing. Crazy $hit!
It's common on drag bikes.
Here's a pic of mine..
The following user(s) said Thank You: Scirocco, Bent Trigger, Dragbike_Mike
  • Bent Trigger
  • Bent Trigger's Avatar Topic Author
13 Jul 2020 16:05 - 13 Jul 2020 16:11
#830600
What happened to Mr Turbo? The site is still up. I'll call the rebuild place tomorrow to see if they can give some info on sizes. Your probably right About an F40 as it came off a 82 KZ1000. Mine drags some and will not coast at all. I also have a list of parts for the S&S Super B carb. Chris
Hahahahah The site I saw is in Capetown South Africa!! My apologies.:P
Last edit: 13 Jul 2020 16:11 by Bent Trigger.
  • urankjj
  • urankjj's Avatar
13 Jul 2020 17:04 - 13 Jul 2020 17:07
#830604
Zed. Is that a Kosman frame ?
Last edit: 13 Jul 2020 17:07 by urankjj.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
13 Jul 2020 18:44 - 14 Jul 2020 10:45
#830610
You can compare Zeds frame to mine ( My teams )
Here are two examples from my racing days
Although rebuilding the turbo is a great idea , It may be OK.
Turbos do not spin super easy . Not much free wheeling . Takes real exhaust power to make them spin and build boost
THESE ARE BOTH Kosman chassis
Last edit: 14 Jul 2020 10:45 by Street Fighter LTD.
The following user(s) said Thank You: Bent Trigger, Dragbike_Mike
  • zed1015
  • zed1015's Avatar
13 Jul 2020 23:16
#830620
urankjj wrote: Zed. Is that a Kosman frame ?
Yes! It's a Kosman frame.
The following user(s) said Thank You: Bent Trigger, urankjj
  • Bent Trigger
14 Jul 2020 04:55
#830627
Any advice on a re-builder for my spare head? Also if I take the Turbo apart for inspection what should I look for as far as indications of NO-GO? I also need help on the way the Impulse line is connected to the waste gate and such. Thanks Chris
  • Dragbike_Mike
  • Dragbike_Mike's Avatar
14 Jul 2020 06:03
#830635
Bent Trigger wrote: Thanks Mike, looks like you've got some serious work into that bike.:cheer: I love the chain driven ignition!! Somehow I don;t think mine will be that involved, but I have been thinking of an inter cooler.:whistle:
You're welcome, Chris. You're getting a lot of good advice here. A lot of KZ knowledge on this website!
Also, some more food for thought - I think that with a "draw- through" system (carb mounted at turbo inlet) you're going to be limited to mounting the turbo behind the motor. The setups that you might see on other bikes with the turbo mounted out front are all using "blow-through" setups that use fuel injection - no carb. If you mount a draw-through up front, you'll get a lot of fuel/air mixture separation by the time it makes it's way to the inlet manifold.
For this same reason of fuel separation, I've never seen an intercooler used on a draw-through system. If I'm wrong, somebody please correct me. Just my .02.
Mike
  • Bent Trigger
14 Jul 2020 06:13
#830636
Thanks Mike, that's good to know and makes perfect sense. I've got plenty of room behind the head so I'll try to make good use of it. Chris
  • zed1015
  • zed1015's Avatar
14 Jul 2020 06:28
#830639
You can't use an intercooler on the draw through.
You could mount the turbo up front and convert to blow through which would mean using a modified bank of carbs with pitot tubes to pressurize the float bowls but i'd just keep it simple as a draw through and use what you have.
  • Moderator
  • Moderator
14 Jul 2020 07:01 - 14 Jul 2020 07:03
#830641
Last edit: 14 Jul 2020 07:03 by Street Fighter LTD.
  • Dragbike_Mike
14 Jul 2020 08:50
#830646
Bent Trigger wrote: I also need help on the way the Impulse line is connected to the waste gate and such. Thanks Chris
That BHP waste gate is capable of being setup as a multi-stage unit. The screw on the end will set your basic level of boost. The airline fitting on the side, at the top, is where you feed in additional air pressure (from a remote air reservoir) to add to the spring pressure on your waste gate valve, thereby increasing boost. The other little fitting coming off on the side, closer to where the 'gate bolts on to the exhaust system, is just a vent, I *think*. To keep things simple, you can just run a fixed level of boost. Hope this helps.
  • Bent Trigger
14 Jul 2020 09:27
#830650
Thanks for the insight guys. I'll be starting with about 5 PSI of boost, and see how hairy it is. Also that FAQ was interesting,and the polishing too. I figured it couldn't hurt to polish the housing scrolls internally. I've got a long way to go before I get this to a running stage. I'll keep ya updated. Thanks Chris
