Retroactive KZ750E Project Thread
- jayrodoh
Re: Retroactive KZ750E Project Thread
07 Nov 2017 14:35
Beautiful rebuild! I did something similar with my XJ650 a few years ago but didn't tear the bottom end of the motor down. I need to go look into that copy cad kit, those parts came out fantastic and I always struggle with hardware replacement. I too am not a pro, just a guy in the garage after the kids go to bed.
1982 KZ750-M1 CSR
- 1slammedkz650
18 Nov 2017 07:49
Very nice restoration,thanks for sharing,learned a few things from this
Cheers !
Cheers !
- Barry2
08 Dec 2017 01:11
An outstanding restoration on your KZ750. I really enjoyed looking at all the photos.
1976 KZ900
- gordone
18 Dec 2017 23:40
You are good !
"Fun" to read through your project
Project:
Project:
- BruceKoukalaka
31 May 2018 20:28 - 31 May 2018 20:29
I realize this thread is a bit old but I would like to know where you got the lines you used for the brakes, I looked at Jegs and all they show is the AN 3 ends. Thanks for the build Nessism I love the bike. I'm presently doing a chopped KZ750H.
Last edit: 31 May 2018 20:29 by BruceKoukalaka.
01 Jun 2018 04:53BruceKoukalaka wrote: I realize this thread is a bit old but I would like to know where you got the lines you used for the brakes, I looked at Jegs and all they show is the AN 3 ends. Thanks for the build Nessism I love the bike. I'm presently doing a chopped KZ750H.
-3 is the correct size for brake lines.
I bought the parts here but there are lots of sources... www.anplumbing.com/hose-ends/speed-seal-steel.html
The following user(s) said Thank You: BruceKoukalaka
- rapfl
04 Aug 2018 02:52
Amazing work! That's one of my dreams for when I have an actual garage, to really take apart a whole bike and restore every tiny bit. Then ride it for another 100k km!
- JohnLuke
- 1982 KZ750N Spectre
08 Aug 2018 20:32
Before you blasted your epoxy primer, how did you prepare the surface? Did you used any solvents? I’m getting my frame blasted and wire wheeling and the other parts that are flat. After I was them with soap and water and dry them, is that okay?
Thanks!
Thanks!
09 Aug 2018 05:27
Wax and grease remover just before paint. It's applied full wet with a cloth and then wiped off with a dry towel. Soap and water will invite flash rust.
- JohnLuke
09 Aug 2018 11:22
Oh okay! What brand did you use? Would simple green do the trick?
Thanks!
Thanks!
- JohnLuke
09 Aug 2018 15:34
Google "wax and grease remover" to find products.
This is one... www.amazon.com/Kleanstrip-Prep-All-Greas...GSW362/dp/B008QDSVPE
