1981 KZ550A2 Update
- rrsmsw9999
Re: 1981 KZ550A2 Update
17 Nov 2015 11:50
Great suggestion Pete. All of the electrical plugs and contacts are cleaned and re greased with dielectric grease. I stop unplugging some stuff as the plastic was quite fragile on a few connectors. I looked enough to check for corrosion and surprisingly they were all very clean that I could expose and the fragile ones looked good too. The loom has no apparent chaffs or broken wires either. All electrics and lights work. It has only 3500 miles before sitting. My experience is that improper routing and miles is what chaffs wires.
R
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- pete greek1
17 Nov 2015 11:58rrsmsw9999 wrote: Great suggestion Pete. All of the electrical plugs and contacts are cleaned and re greased with dielectric grease. I stop unplugging some stuff as the plastic was quite fragile on a few connectors. I looked enough to check for corrosion and surprisingly they were all very clean that I could expose and the fragile ones looked good too. The loom has no apparent chaffs or broken wires either. All electrics and lights work. It has only 3500 miles before sitting. My experience is that improper routing and miles is what chaffs wires.
R
That's good ta hear , many people overlook things like that
Keep us posted with your progress
Pete
- rrsmsw9999
18 Nov 2015 06:03
Gonna go with KBS Gold Standard tank sealer. The pinholes are underneath and only one leaked, so I hopefully will not be doing additional bodywork/paint. I temporarily JB welded the leaker so i can clean gas out with denatured alcohol, wash and then dry before install. The tank has been etched and derusted already. Fingers-crossed. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- rrsmsw9999
Re: 1981 KZ550A2 Update - MORE
23 Nov 2015 18:44
Here are some latest pics. new tires. i have to deal with the master cylinder still, but probably done till spring. The airbox hoses are on backorder at Z1 and there will probably be a foot of snow at that time. Also have tank sealer to try out, but I may try to solder first as the pinholes are under the tank out of sight. Either way, it's already colder than the sealer directions dictate. It fires over but runs rough. I may have a residual ignition probaby with the cleaned up pulse ignition. She will sleep till spring. battery coming in the house over the next few days.
Attachment IMG_1424.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- rrsmsw9999
23 Nov 2015 18:45
Attachment IMG_1424-2.jpg not found
Attachment IMG_1425.jpg not found
Attachment IMG_1426.jpg not found
Attachment IMG_1427.jpg not found
Attachment IMG_1428.jpg not found
Attachment IMG_1431.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- rrsmsw9999
23 Nov 2015 18:52
BTW the Shinko 712 front tire spooned on real easy. The rear was a bit of a pain. Surprising given the drop zone on the rear is quite a bit larger, I thought the rear would be the easy one. Harbor Freight changer, but just used spons with the tires clamped down. The HF bar sucks for install, good for demount. Spoons work well on the Vulcan rims to especially to not pinch the tubes. The old tires were so hard I just cut em off with a hacksaw and chiseled the bead. Easy peasey R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- rrsmsw9999
23 Nov 2015 19:24
Also forgot to mention. I ran through all the gears up and down.
Smooth shifting and no leaks from the tranny cover I replaced. Happy motoring.
R
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- chirpy999
23 Nov 2015 20:55
Nice one, I like that paint job youve dropped on alright there!!!!
24 Nov 2015 05:57
Bike looks good! Ed
The following user(s) said Thank You: rrsmsw9999
- rrsmsw9999
25 Nov 2015 15:48
A few master cylinder repaint pics. Don't send the colorblind guy to get paint. Green under black. R
Attachment IMG_20151125_175414593_HDR.jpg not found
Attachment IMG_20151125_175305613_HDR.jpg not found
Attachment IMG_20151125_175447888_HDR.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
25 Nov 2015 16:25
So it's not black? Is the red a reflection?
- Tyrell Corp
25 Nov 2015 16:47
Nice to see the 550 puts a smile on yer face, does it for me too... for the last 25 years.
Just looking at those pics I get a buzz from, such nice looking bikes. $200 is silly cheap.
Nice find, keep at it.
