1981 KZ550A2 Update
- rrsmsw9999
Re: 1981 KZ550A2 Update. new seat cover
04 Jan 2016 09:06
Got my seat cover off ebay and I will say it is top notch quality, looks great and made to fit the stock 550A pan. It is pleated and has a top cover seam where the pleats join the sides. Seller doesn't recommend using the grab strap. Will get some pics and vid when I take up the job tonight.
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- Tyrell Corp
04 Jan 2016 15:36
When fitting seat covers, I do it in front of a gas fire and carefully heat the vinyl, it stretches better for that skin tight look. I use a stapler, also if the foam is damaged use some thin upholsterers wadding, but don't over do it, no-one wants a fatty seat.
- rrsmsw9999
04 Jan 2016 16:00
Here are the seat pics. Like everything on this bike, I did my best. It all has turned out 99.5% to my liking.
What do you think?
R
What do you think?
R
Attachment IMG_1472.jpg not found
Attachment IMG_1473.jpg not found
Attachment IMG_1474.jpg not found
Attachment IMG_1475.jpg not found
Attachment IMG_1476.jpg not found
Attachment IMG_1477.jpg not found
Attachment IMG_1478.jpg not found
Attachment IMG_1479.jpg not found
Attachment IMG_1480.jpg not found
Attachment IMG_1481.jpg not found
Attachment IMG_1482.jpg not found
Attachment IMG_1483.jpg not found
Attachment IMG_1484.jpg not found
Attachment IMG_1485.jpg not found
Attachment IMG_1486.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
04 Jan 2016 16:14
Looks good. You may want to tighten it up a little after it gets broken in. I wish you had left more material in the back. It might have to move forward a bit.
- rrsmsw9999
04 Jan 2016 16:32
Thanks Swest.
The pleated section has a heavy backer and 1/2" of foam stitched into the seat. If it does stretch and I am 200# so it probably will my guess is it will be the back and side panels. Nice thick vinyl all over and quality stitching. A bargain for $28.
Not the easiest job. If I have to do over at some point I will use the upholstery tack strips that can be riveted to the pan. Even though I made a few tangs and checked carefully, some of the original tangs were difficult to punch through the thicker material at the section seams. The tack strips have much larger tangs and are sharp as hell. Used a little contact cement on the front flap and tucked one corner under the rubber.
Anyway It feels good on the butt. :lol:
R
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
04 Jan 2016 16:38
That's what matters.
- rrsmsw9999
Re: 1981 KZ550A2 Update - Meter Madness
22 Jan 2016 12:39
Let the fun begin :woohoo:
Will post through the job.
R
R
Attachment IMG_1492.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- rrsmsw9999
22 Jan 2016 21:15
Here are the pics. Out late tonight, wooohooo.
There are some marks on the crimp band that I am not willing to obsess over. For 19$ including glass and paint I am happy with the resulte. If I can find a proper size rubber band or trim piece I will cover the crimp band. Pretty easy job overall take a bit of patience.
R
R
Attachment IMG_1497.jpg not found
Attachment IMG_1498.jpg not found
Attachment IMG_1499.jpg not found
Attachment IMG_1500.jpg not found
Attachment IMG_1501.jpg not found
Attachment IMG_1512.jpg not found
Attachment IMG_1515.jpg not found
Attachment IMG_1516.jpg not found
Attachment IMG_1517.jpg not found
Attachment IMG_1518.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
23 Jan 2016 04:48
Very nice. I use my lineman's pliers with the wide square jaws to recrimp them. less marks that way.
- rrsmsw9999
Re: 1981 KZ550A2 Update- Ride report
31 Jan 2016 13:46
Got 10 miles in yesterday, 50 today. It is running as it should. I really like the Shinko 712s. Good cold and wet traction. It was a summer like 40 here the past two days, A few pics. A vid link will be around shortly. R
Attachment kawp1.jpg not found
Attachment kawp2.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- rrsmsw9999
31 Jan 2016 13:56
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- rrsmsw9999
31 Jan 2016 13:57
Let it perk a bit and the HD will get up to 1080-60p. Bad camera angle, but you get the drift. :evil: R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
