1981 KZ550A2 Update
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1981 KZ550A2 Update
09 Feb 2016 07:03
#710100
Sounds like a good plan. ;)
  • harm
  • harm's Avatar
  • Tom
Re: 1981 KZ550A2 Update - Engine removal and teardown
09 Feb 2016 07:20
#710111
rrsmsw9999 wrote: At 3500 miles I can't imagine rings or pistons being an issue.
Just something else to consider, with the TK carbs that you have, were all the choke flaps present? If not, they most likely went through the motor. they usually don't do horrible damage but can ding the top of the piston or "pinch" a ring on the piston. It's probably fine but i had this when i took my top end off. The ring pinch was very minor and i was able to clean up the piston ring groove carefully and its been running great for years now!
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
  • rrsmsw9999
  • rrsmsw9999's Avatar Topic Author
09 Feb 2016 08:51
#710138
Sound advice.
Yes been inspected and they are all present, inspected and stake glued.
Thanks
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • rrsmsw9999
09 Feb 2016 08:55
#710139
Yeah, guessing so as well. A few odd seals not in any kit,cover allen bolt set, cam end plugs, 1194 for the case, clutch hub holder shot right up to over a Grant quickly. There is only one way to this, the right way :silly:
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • dom2570
  • dom2570's Avatar
09 Feb 2016 11:11
#710151
It really sucks about the bottom seal, but I'm not going to lie I am kind of excited to see your progress. Keep the videos coming, especially if you split the cases they defiantly could become a good resource.
Whip it like a mule!
  • rrsmsw9999
09 Feb 2016 12:50
#710173
Yes I will video a lot as much for me rather than viewing pleasure. :woohoo: Of I have pics or video I'll take video. Edited versions will get to you tube and links posted here. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Feb 2016 13:38
#710180
That's how I do it. B)
  • rrsmsw9999
10 Feb 2016 06:28
#710266
Been reading and studying a lot, parts and supplies on the way. I will begin prep for engine removal once it gets above 10 frigging degrees again. It's been - single digits during this cold snap that is now on its third day and won't let up til Sunday. Winter is long in WI :lol:
One question I have seems basic but I wanted to ask. It would seem to me that both the clutch hub bolt and flywheel bolt could be freed using the drive train and rear brake rather than any special holders, and then torqued after back in the frame. Any thoughts here? Any shortcuts on a proper flywheel puller? Given I have the right side crank oil seal leaking, I will replace the left side too, not buttoning back up one remaining 35 year old crank oil seal. ;) Secondary shaft/starter clutch also has to come out to split. Wanna make sure those bolts are freed before out of frame and no decent flywheel holder is available. That would suck. Feeling confident on this. I am good enough, strong enough, and gosh darnit, people like me ! R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Feb 2016 07:02
#710271
You shouldn't have to do that. The only seals are on the points side and the sprocket side. You should be able to take the covers off, the advance and sprocket off now. With the engine upside down, the lower half should come right off once the pan is off of course.
  • rrsmsw9999
10 Feb 2016 07:13 - 10 Feb 2016 07:35
#710273
Looking a the manual I don't see how the lower case comes off with out removing the secondary shaft. It's in the bottom half chained to the crank when not removed. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Last edit: 10 Feb 2016 07:35 by rrsmsw9999.
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Feb 2016 07:31
#710276
The crank bolts got through the case and there are a few under the pan. When you get the engine out, take some pics of the bottom and the top so we can coach you through the process. I should have taken pics of my tranny swap. It would've been easier but I was in a hurry to ride. :woohoo:
  • rrsmsw9999
Re: 1981 KZ550A2 Update - K&L MC 25 engine stand
11 Feb 2016 15:20
#710505
I know how you guys like pics so see below.
Nice stand, but pricey to not come with the elevator hitch pins.
R
Attachment IMG_1524.jpg not found
Attachment IMG_1525.jpg not found
Attachment IMG_1526.jpg not found
Attachment IMG_1527.jpg not found
Attachment IMG_1528.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
