The Friendship Bike - NobleHops restores a 75 Z1
- NobleHops
- A happy present from the earth!
Re: The Friendship Bike - NobleHops restores a 75 Z1
18 Sep 2015 11:45 - 19 Sep 2015 10:26Kidkawie wrote: Thanks for the info.
I'm going to start with just springs. If I want to go any further I'm going to source a set of spare forks or damper rods first.
I was just finishing up modifying a set of ZRX shocks and found a bad bladder, so I'm trying to source one of those now.
If you go with springs and THEN decided you wanted to add the emulators, you could run into problems, because the emulator and adapter stack will put too much preload on the springs. shorter length springs require longer spacers for this very reason.
Nils Menten * RestoCycle LLC * Tucson, Arizona * USA
Proud sponsor of KZRider: kzrider.com/forum/14-vendor-forum/604812...on-shocks-usa#751083
Vapor blasting with free shipping! www.restocycle.com
Discounted Ikon Shocks! www.ikonshocksusa.com
Last edit: 19 Sep 2015 10:26 by Patton. Reason: rule compliance
- Stev-o
19 Sep 2015 07:10
Hey Nils...I found you. Nice write up of the front fork mods, think I will copy you this winter and may need help with the lathe work.
not all of us are as lucky as you to have a well equipped shop!
-S
-S
'75 Z1 '74 H1 '74 H2 basket case ..... plus plus plus...
- z1kzonly
19 Sep 2015 08:16
Cyanoacrylate variants, aka "Crazy glue". Example:
www.amazon.com/MxBons-Premium-Ring-Glue-Instant/dp/B00IOFVO2G
Thanks for this tip on this product! I ordered some.
- NobleHops
19 Sep 2015 08:38z1kzonly wrote: Cyanoacrylate variants, aka "Crazy glue". Example:
My pleasure!
- NobleHops
19 Sep 2015 08:39Stev-o wrote: Hey Nils...I found you. Nice write up of the front fork mods, think I will copy you this winter and may need help with the lathe work.
-S
Steve-o!
Anything you need man, that was fast and easy to do. I'll drill them for you too if you want. Anytime!
N.
- NobleHops
19 Sep 2015 08:41 - 19 Sep 2015 10:09Kidkawie wrote: Thanks for the info.
If you go with springs and emulators, you could run into problems, because the emulator and adapter stack will put too much preload on the stock springs. shorter length springs at the same nominal spring rate that require longer spacers for this very reason.
Last edit: 19 Sep 2015 10:09 by Patton.
- Rockranch
29 Sep 2015 14:30
Are those 28SS Mikunis from the Z1 900 era?
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
1 modified
- NobleHops
29 Sep 2015 18:48Rockranch wrote: Are those 28SS Mikunis from the Z1 900 era?
Sorry man, I have no idea of the context of this question, Are you referring to a specific post? Mind quoting that post and if I can answer you, I will?
- Rockranch
30 Sep 2015 00:19
Sorry this reply went awry. It had to do with the set of carbs you were cleaning and needing a part for. I have lots of Mikuni's and I might have been able to help you.
1 modified
1 modified
The following user(s) said Thank You: NobleHops
30 Sep 2015 02:34
Got any 33mm parts?
- Rockranch
30 Sep 2015 02:44
Sorry Steve no 33's. Mostly 28's & 26's. I just rebuilt a set of 38mm Mikunis for my big block 1327 and I'm absolutely loving the throttle response, especially from low rpm's.
1 modified
1 modified
- NobleHops
30 Sep 2015 04:54Rockranch wrote: Sorry this reply went awry. It had to do with the set of carbs you were cleaning and needing a part for. I have lots of Mikuni's and I might have been able to help you.
That is super cool of you, thanks so much. In fact I have at least one more set of Mikunis to rebuild and so I may take you up on that. Thanks a ton Rock.
N.
