Kz 440
- dom2570
Re: Re:Re:Kz 440
21 Feb 2015 17:04Honestly, I have no idea. I've kind of been blindly following threads were people claim to have gotten it all worked out. I'm kinda bashing my head against the wall at this point. Luckily I am going to switch gears and focus on my new toy.swest wrote:dom2570 wrote: Oily was probably a really bad way to describe it, they are just really black.
Is that carb normally for a two stroke?
The new bike is an 81 kz440 but complete. I haven't got a chance to do anything with it, but it looks good.
Whip it like a mule!
- dom2570
- dom2570
Re: Kz 440
23 Feb 2015 12:29 - 23 Feb 2015 12:30Carb is set up with
Main 160
Pilot 30
Needle jet Q-0
Needle JN6F9
I have been beating my head against the wall with this thing lol. I have not checked for any air leaks that is next on the list as I run out of ideas. The new bike looks like it will be much less work so hopefully I will get a little bit of a brain break while I get her going.
Last edit: 23 Feb 2015 12:30 by dom2570.
Re: Kz 440
23 Feb 2015 13:05
Now there you go. Flogging a dead horse with the other one.
- dom2570
Re: Re:Kz 440
23 Feb 2015 13:15 - 23 Feb 2015 13:16
I'm pretty sure the new bike is going to be stupid simple. It looks clean and has a complete airbox! The po said it was having trouble shifting gears....someone put the shift lever on wrong and it was hitting the stator cover and getting caught. Lol
If all else fails, I'll be able to make one good bike from the two.
Last edit: 23 Feb 2015 13:16 by dom2570.
- dom2570
Re: Re:Kz 440
21 Mar 2015 17:54
After checking the timing mechanism on my other 440, I figured I would check this one's too.
It was completely seized, up I'm guessing whis is why the big would straight up die at certain rev ranges
- dom2570
Re: Re:Kz 440
31 Mar 2015 16:25
I have a stock exhaust, the headers look great, but the mufflers are rusted out and have sever holes.
I was thinking about cutting them off and adding some slip ons. Has anyone had any luck with that?
- dom2570
Re: Kz 440
12 Sep 2015 10:19
Hobbes lives again! The carb boots on my other 440 were destroyed so I was kind of dead in the water as I don't have cash to be throwing at toys right now. Then it hit me that the timing advancer or spark thing was completely locked up when I was trying to get the single carb to run right. I had the girlfriend come over and help me do yet another engine swap. I also had her cut me out some new gaskets for the single carb manifold. Today I got most of it together and was shocked when it fired up! No more carb backfire or anything. Hopefully I will get it out and do a road test tonight!
- dom2570
Re: Re:Kz 440
16 Sep 2015 17:53
I was having issues with the throttle cable sticking, so I decided to run it through the backbone. It is much smoother and cleaned up the look.
The mikuni carb is doing great. I have put a couple hundred miles on it so far and am getting about 45mpg. I have reached red line in all 6 gears just to see how it performs. I'm really impressed at how smooth it runs compared to my stock 440.
- loudhvx
Re: Re:Kz 440
17 Sep 2015 07:02
Nice work. The throttle cable trick is pretty slick.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- dom2570
Re: Re:Kz 440
28 Sep 2015 11:32 - 28 Sep 2015 11:34
The bike has been treating me pretty good. I need to pick up some new plugs and tune the carb a bit better. So far I have used GPS and topped out at about 88mph. The shop manual specs say top speed is 107. I know the bike is 34 years old, and no longer stock but what should I check out to get a little bit more power, if possible?
The exhaust is pretty free flowing, would that be hindering performance? I hate how loud they are and am looking for something a bit more restricted.
Last edit: 28 Sep 2015 11:34 by dom2570.
Re: Re:Kz 440
28 Sep 2015 12:50
I would suspect that single carb is not helping your top end speed. Dual carbs on a twin provide the extra oomph needed. That's why the 500cc BSA racing engines (Cyclone) had dual carbs while the tame street version 500cc engines had single carbs. Ed
Attachment 00003b-34.jpg not found
Attachment BSA-A50-Cyclone-65-2.jpg not found
