Neighbourdave's Z1-R resto
- mopguy
Re: Neighbourdave's Z1-R resto
21 Jan 2015 16:48
Looks good, did Brian do it?
- kaw-a-holic
21 Jan 2015 17:22
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationhere is a link from eBay for repro VIN tags
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- neighbourdave
22 Jan 2015 06:48mopguy wrote: Looks good, did Brian do it?
Yes he did. Great guy, quick turn around.
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
- neighbourdave
22 Jan 2015 06:49
That is interesting.
kaw-a-holic wrote: here is a link from eBay for repro VIN tags
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
- mopguy
22 Jan 2015 08:06
I am glad that you are happy with the reproduction decal he made for you, the ones that are on E-Bay are not exact reproductions, and I don't think they will pass here in Canada with the Ministy of Transportation.
- DOHC
- Those Doe-Hawks really go!
26 Jan 2015 17:59
Here is the top half with the switch stalks and at least one of the switch buttons.
neighbourdave wrote: Also, can anyone help with turn signal auto/manual switch? My switch stalk is broken and the knob is missing.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- neighbourdave
27 Jan 2015 06:57
Thanks dohc!
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
- DOHC
01 Feb 2015 20:39neighbourdave wrote: Thanks dohc!
Did you get it? If not, I may be able to help...
'78 Z1-R in blue
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- neighbourdave
02 Feb 2015 07:31dohc wrote:neighbourdave wrote: Thanks dohc!
I did! For $18.00 ($41.00 shipping).
Thanks again.
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
- neighbourdave
11 Feb 2015 06:09
I have all the wiring back in place and everything is working except for the auto cancel signals. Does any one know if there is a common problem with this set up? Or any clues as to where to start looking?
Attachment IMG_20150210_174021.jpg not found
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
- DOHC
11 Feb 2015 08:22 - 11 Feb 2015 08:23neighbourdave wrote: I have all the wiring back in place and everything is working except for the auto cancel signals. Does any one know if there is a common problem with this set up? Or any clues as to where to start looking?
I should be able to help, but it may be a bit tricky to test on the bench. I'm pretty sure that if the front wheel is not moving, it will never trigger the auto-cancel. You can sit at a stop light as long as you want with the signal on.
Do you have a way to drive the speedo cable? That would be a good first start. Maybe a drill?
I would test the solenoid in the switch housing first. My solenoid had a blown thermal fuse inside. The timing box on my bike burned up and caused the solenoid to be permanently active, at least until the thermal fuse attached to the solenoid opened up. You should be able to briefly apply 12V directly to the solenoid wires to confirm that it's pulling in and releasing the signal selector switch.
If the solenoid checks out, I'd test the speed sensor next. This is just a simple reed switch and magnet. The sensor can be tested easily with a continuity tester (which most voltmeters have). Just connect the continuity tester across the two leads of the sensor and turn it. You should get several switch open/close transitions per revolution. I can test mine to give you exact number, but if the switch opens and closes as you turn it it is probably just fine.
The only other part is the control box, and that's just a black box filled with epoxy. You can confirm the connector contacts are in good shape, and that the input and output wires all reach their destinations, but that's it.
I believe if you activate the turn signal, and drive the speedo cable fast enough, it should kick in. If it doesn't, check the wiring and contacts again. If it still doesn't work, find a new control box.
If you need the wiring diagram, it's in the file database:
kzrider.com/filebase/search/finish/1-general/251-1000d1
'78 Z1-R in blue
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 11 Feb 2015 08:23 by DOHC.
- neighbourdave
11 Feb 2015 08:25
Thanks dohc.
I had the drill attached to the speedo cable last night.
I will check the coil and signal generator tonight.
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
