Neighbourdave's Z1-R resto
  • dkoz
  • dkoz's Avatar
Re: Neighbourdave's Z1-R resto
09 Jan 2015 06:25
#658150
I believe that mounts under the coils.? I won't be home for about an hour or two I'll run out to the garage and check under my z1r
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
  • dkoz
  • dkoz's Avatar
09 Jan 2015 06:37
#658151
My manual reads it mounts on the front mounting bolts of the ignition coils.install the resistor so that the leads are toward the front side.
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
  • neighbourdave
  • neighbourdave's Avatar Topic Author
09 Jan 2015 06:51
#658154
That's great! Thanks.
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
09 Jan 2015 06:53
#658155
on my 80z1r it mounts across the front set of coil mounting bolts .like dkoz said.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
12 Jan 2015 18:10 - 12 Jan 2015 18:11
#658534
neighbourdave wrote:
Grumpy Ole Artist wrote: With a clear pic & dimensions (or a carefully peeled sticker I could slap on the scanner) I could reproduce a vin sticker for ya..(PM me!)
Thanks for the offer but the sticker is long gone and my picture of it is not very clear.
I'd be happy to provide pictures of mine to use as a reference. I assume it wouldn't be too hard to change the frame number to match your frame... Plus, I need a reproduction sticker too. :)
Do you have any pictures of your original sticker that show the build date for your frame?
My dad's '74 Z1
'00 ZRX1100
Last edit: 12 Jan 2015 18:11 by DOHC.
  • neighbourdave
14 Jan 2015 06:06
#658646
dohc wrote:
650ed wrote: Is there any way to protect or temporarily remove the VIN label on the neck of the frame? Ed
I've seen folks mention buying reproductions of these stickers with all of the correct info. Using a good reproduction seems much easier than working hard to refinish every inch of the frame except that little bit under the factory sticker. :)
I dug up this post that has a link to someone who makes reproductions:
kzrider.com/forum/11-projects/496842-kz1000?start=40#572846
I contacted the company at this link and he seems positive about being able to reproduce my sticker.
I will post about how it goes.
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
  • neighbourdave
14 Jan 2015 06:11 - 14 Jan 2015 06:13
#658647
I am working on the hand controls right now.
Can anyone help with the correct colour? Is it a satin or gloss black?
Also, can anyone help with turn signal auto/manual switch? My switch stalk is broken and the knob is missing.
Attachment IMG_20150112_110412.jpg not found
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
Last edit: 14 Jan 2015 06:13 by neighbourdave.
14 Jan 2015 07:02
#658649
The original finish is not super high gloss. The picture below shows a new old stock control for the KZ650-C1. Ed
Attachment 00003a_2015-01-14.jpg not found
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
14 Jan 2015 07:33
#658654
Airbrush artists use a masking material called "frisket" it is transparent & easily removable...it would be a simple matter to mask off sticker prior to paint...no help for powdercoating though...simple masking tape would work fine, but, not being transparent, it would be a little more difficult to trim with x-acto knife to conform to edges of sticker...Actually clear shelf paper would work if no art supply stores local!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
  • K.D. HART
  • K.D. HART's Avatar
14 Jan 2015 08:13
#658660
Puffin wrote: B) Nice find, looks pretty complete, what make are those pipes
Wirges, and it is really complete!
I was invited to go meet Bill Wirges last week. He's 82 now.
Can't wait to see the salt flat bike he run in 1972!!!!!!!
[IMG
[IMG
[IMG
  • neighbourdave
14 Jan 2015 08:57
#658666
Well that is a cool opportunity.
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
  • neighbourdave
21 Jan 2015 04:13 - 21 Jan 2015 04:15
#659243
Attachment IMG_20150120_164900.jpg not found
Here is my new sticker. I am quite happy with it.
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
Last edit: 21 Jan 2015 04:15 by neighbourdave.
