Better Than Nothing---The rebirth of a Superbike.
- Vinsky
Re: Better Than Nothing---The rebirth of a Superbike.
29 Feb 2024 21:04 - 29 Feb 2024 21:18
I had Morris mags on my first Z1. Sold them and got Lester wheels. That was back when I had built some Kawi frames for the Lester Wheels WERA team. Morris mags were cast at AM Casting a block from my shop. Now I couldn't afford a set even if I could find them.
Vinsky
Last edit: 29 Feb 2024 21:18 by Vinsky.
- Move0ver
01 Mar 2024 07:15 - 01 Mar 2024 07:16
PMC makes some lightweight KZ wheels:
japan.webike.net/products/23760936.html
Front 3.8kg / Rear 5.9kg
About $2000 for a front/rear set
Last edit: 01 Mar 2024 07:16 by Move0ver.
The following user(s) said Thank You: Vinsky
- Vinsky
02 Mar 2024 07:55 - 02 Mar 2024 07:56
At 82 I have more wants than needs and more projects than time left to complete so I guess I do a lot of dreamin. Some days I think of turbocharging my Z1R project then realize I just need to get it done.
Vinsky
Last edit: 02 Mar 2024 07:56 by Vinsky. Reason: typo
The following user(s) said Thank You: Mcdroid, ThatGPzGuy, Nessism, MFP-Joe, sf4t7, Cra-z1, Wookie58
- Dr. Gamma
09 Oct 2024 15:56
FYI
I was getting my Superbike ready for a quick trip down the back roads near my house. I had a hard time starting it and when I got it running it just didn't sound right!!!! I always drain the carbs and gas tank before I park it. Took the carbs off for a look around. I found another broken plastic nut on one of the enricheners ( the choke plungers} again. As I was replacing the broken one I found another one that had loosen!!!! By my notes neither one was the one I replaced a few years back!!! Since I had the carbs off I replaced those o-rings around the needle seats and reset the float heights again. Fired it up and it still sounded like it was still rich. Pulled them off again and try to find what was going on. Nothing looked out of place. As a last resort I pulled one of the enricheners out of a carb. The rubber inlay on the enrichener that seals off the fuel from coming up the passage was hard as a rock and deformed from sitting down on the passage!!!! Lucky I had four new ones on hand. THANKS TO THE GREAT SELECTION OF KEIHIN PARTS AT THE NOW GONE SUDCO INDUSTRIES!!! After replacing them in the carbs and putting them back on the bike. The bike fired up in two kicks and sounded healthy as hell!!!! From now on I am going to store my CR's with the enricheners not sitting in the seated position!!!! I hope that will keep those little rubber inlays from getting hard and deformed!!! It might be a good idea for anyone with Keihin CR's on their bike to do the same.
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: Mcdroid, sf4t7, Dragbike_Mike, howardhb, Wookie58, Rolf1976_KZ900, kimchella
- Dr. Gamma
17 Mar 2025 13:38 - 17 Mar 2025 13:40
Due to a lack of funds, I could not afford to heat my whole garage this winter. It was a choice between the extra cost of heating the garage or food in my stomach. I went for the food!!!! So I ended up buying a heated bike blanket for my beloved MK.II. I just could not see my MK.II sitting there in a very cold garage. The Suzuki's will just have to make do with the cold!!! There have been a few nights where it got down into the low 20's here up in the mountains in Arizona. The bike blanket seems to work out pretty good!!!!
Last edit: 17 Mar 2025 13:40 by Dr. Gamma.
The following user(s) said Thank You: MFP-Joe, kimchella
17 Mar 2025 17:00
As long as it’s dry the cold shouldn’t hurt it too much but “a man’s gotta eat”
- Dr. Gamma
29 Sep 2025 15:32
I have not been posting too much in the past months or so. My health has not been the best lately. Just spent like two and half months in the hospital and then a rehab center. Can't believe what the hospital bill came to!!!!!! Thank God for insurance companies!!!!!! I still have a long way to a complete recovery. It really sucks to get old and sick..................
And NO my bikes are not for sale!!!
The following user(s) said Thank You: rstnick, Nessism, MFP-Joe, SWest, Gdizard
30 Sep 2025 00:06
Sorry to hear that Doc, hopefully you are "on the mend now". The nice thing about our bikes is they won't eat or drink anything while they slumber and when you are ready they will be waiting. Be well
The following user(s) said Thank You: Nessism, Dr. Gamma, Gdizard, kimchella
- MFP-Joe
30 Sep 2025 11:56
I wish you also a full recovery to good health. Never give up !!!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Z1000 A2 1977
Greetings, Joe
The following user(s) said Thank You: Dr. Gamma, SWest
- riturbo
04 Oct 2025 16:36
Hang in there . It takes longer to heal as we get older .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
