lushbaughs kz
  • lushbaugh
  • lushbaugh's Avatar Topic Author
  • everybodys a pro......
Re: lushbaughs kz
28 Dec 2012 01:21
#564948
Kitten Tooth wrote: Yep hahaha but im thinking a KZ1000 drivetrain can handle it. doesn't mean i should keep doing that stuff though. :D
i used to think that too :laugh: but im hard on bikes, blew a few motors in my time. im trying to figure out a way to remedy this cause ive seen a few kz clutches like this or at least close. basket is like new its just the springs so i dunno what the issue is. but if i broke it once you can bet your ass i wont break the same part twice. overkill it on the rebuild :evil:
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
  • DoubleDub
  • DoubleDub's Avatar
Re: lushbaughs kz
28 Dec 2012 01:37
#564950
I'm sure Jay wouldn't mind me stating that this might be a solution :whistle:
KZ HEAVY DUTY CLUTCH HUB ASSEMBLY
The strongest modified clutch hub assembliy available. Consisting of our heavy duty clutch hub kits installed on customer supplied clutch hub. We must have a good clutch basket / gear assembly from the customer.
GHK1000 Z1, KZ1000 thru '80 $174.00
kzzone.com/clutches.html
  • DoubleDub
Re: lushbaughs kz
28 Dec 2012 01:38
#564951
These are probably better than the originals too...
CLUTCH HUB REBUILD KIT
For the do it yourselfer. Kit includes heavy duty springs and rivets.
CHK1000K Z1, KZ1000 thru '80 $95.00
Same link.
  • wireman
  • wireman's Avatar
Re: lushbaughs kz
28 Dec 2012 07:57 - 28 Dec 2012 07:59
#564970
Attachment Image_2012-12-28.gif not found
The other option,shaft drive clutch basket asemb B)
Last edit: 28 Dec 2012 07:59 by wireman.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: lushbaughs kz
28 Dec 2012 10:38 - 28 Dec 2012 10:43
#564974
Falcon provides a heavy duty billet clutch basket for KZ......a bit $$$$$$$$$ though.
Last edit: 28 Dec 2012 10:43 by 4TheKZ1000.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: lushbaughs kz
28 Dec 2012 12:43
#564985
is the shaft drive basket stronger/meatier?
  • lushbaugh
Re: lushbaughs kz
28 Dec 2012 13:10
#564987
4TheKZ1000 wrote: Falcon provides a heavy duty billet clutch basket for KZ......a bit $$$$$$$$$ though.
thats nice but out of my beer budget hahaha and leon the shaftie basket has more plates distributing power acrost more surface area. im thinking the spring retainers and springs are the weak link, the retainer has a sharp edge that cuts a grove into the spring and the spring is mayhaps brittle. if you look at the rolled edge around the spring pocket youll see the angle on it is harsh and unsmoothed. im guessing the torque of the launch is causing a sheering action against the spring.
  • lushbaugh
Re: lushbaughs kz
28 Dec 2012 13:13
#564988
seems jays kit addresses the rivets and springs but there's def an issue with the spring pocket anyone ran into this?
  • lushbaugh
Re: lushbaughs kz
28 Dec 2012 13:16
#564989
also im sure someone somewhere has the idea that im just throwing money at this thing, just so everyone is aware im getting alot of used parts and parts made from wireman and wheeling and dealing with members. im 24yr old single dad\mechanic with cutback hours and a lil sidework to help. i drink pabst blue ribbon and eat cheap to make this shit happen.so anyone can do this project stuff.
  • 4TheKZ1000
Re: lushbaughs kz
28 Dec 2012 13:17 - 28 Dec 2012 13:37
#564990
I know you have been around the block with KZ builds and probly looked at this stuff 10 times....but if you missed it, might help....LOL
Redline has a heavy duty banded hub.... www.redlinecycle.com/Clutch%20Hub.html
Rebuild Kit: store.starracing.com/servlet/Detail?no=549
Last edit: 28 Dec 2012 13:37 by 4TheKZ1000.
  • DoubleDub
Re: lushbaughs kz
28 Dec 2012 19:37
#565013
That second link looks like the APE kit.
Sometimes there's pieces money has to be thrown at. Not suggesting it needs to be done everywhere. I've thrown away my share on my build - it won't happen the next time.
  • 4TheKZ1000
Re: lushbaughs kz
28 Dec 2012 19:54 - 28 Dec 2012 20:18
#565015
Last edit: 28 Dec 2012 20:18 by 4TheKZ1000.
