KZ750E1 - FIGHTER Build
  • 650mod
  • 650mod's Avatar
Re: KZ750E1 - FIGHTER Build
10 Mar 2013 08:00
#576314
Mike,
When the kickstand is up, will it hit your shifter? What I'm looking at doing with my rearsets (when I get there) is mounting them further back, just behind the rear frame vertical tube. It's a bit further back, and looks like it'll save hitting the shifter. Different riding position, but should work.
As for paint- I'm touching up my frame this year after my build is complete with a spray can job (rollbar paint), then ripping it fully down for powdercoating over next winter. That way if anymore work is needed on the frame, you're not wrecking any of your nice paint work. All personal preference, and just one way to go about it.
The build looks amazing, though. Keep us posted!
Devin
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
  • mike0537
  • mike0537's Avatar Topic Author
14 Mar 2013 00:15
#576879
Got all the welding done on the frame and the shock mount completed. Then cut off and ground all unnecessary stuff. Moved kickstand and trimmed it down. Painted frame. Now reassembly time!
1980 KZ750E
  • mike0537
26 Mar 2013 03:07
#578818
Okay so here is my $20 exhaust. Off of a 99 Bandit. Still need to make a muffler hanger bracket.
No it didn't bolt right up. I had to do some bending and cutting and welding. I welded on my stock pipes flanges. The welds are behind the header brackets so they can't be seen. Hopefully it will sound good. I may try to bend up the muffler pipe to bring it up at more of an angle but I'm not sure yet...What do you all think?
1980 KZ750E
  • 650mod
  • 650mod's Avatar
26 Mar 2013 10:46
#578862
Nice progress, Mike! Looks really slick. As for the exhaust, that's a sweet $20 deal!!! How much of a drop did you end up with after swapping the front/rear end? On my build, my forks/tire combo drops my front end 4", not sure about the rear yet. You might want to try and bend it up to gain a bit of side clearance if you're going to be leaning it over often. I'm running an exhaust off an '01 Z750 on my bike, and it's got a nice little kick up at the rear section, cleans the look of the bike up a bit and gives a little more clearance for hard lean-overs. In the end, it's your bike, your call on what feels natural.
Here's what the exhaust on my bike looks like
Attachment 2001-Kawasaki-ZR750-mine-b-small.jpg not found
Devin
78 kz 650 custom
  • mike0537
04 Apr 2013 02:58 - 04 Apr 2013 03:00
#580499
Got the exhaust all done. Starting with the wiring now. Also got the battery box built and mounted. Hand controls are mocked up as well.
1980 KZ750E
Last edit: 04 Apr 2013 03:00 by mike0537.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
04 Apr 2013 09:55
#580515
mmmmmmmmmmmmm,lookin nice :evil: !!!!!!
  • donthaveakawman
  • donthaveakawman's Avatar
04 Apr 2013 16:24
#580563
mike0537 wrote: Got the exhaust all done. Starting with the wiring now. Also got the battery box built and mounted. Hand controls are mocked up as well.
check your private messages
  • mike0537
24 Apr 2013 02:56
#583795
Took her for a ride tonight!! I'm getting some pretty good chain noise, slight exhaust leak and my exhaust scrapes when turning right. It was only about 2 miles and it was cold but fun to get back on!
Tank is painted but still working on fenders and side covers.
[IMG
1980 KZ750E
  • 531blackbanshee
  • Vendor
  • Vendor
24 Apr 2013 10:07
#583813
looks like you could use a rub strip on the front of that arm under the chain run.
  • Jrbrownie00
  • Jrbrownie00's Avatar
24 Apr 2013 13:13
#583825
are those levers / master cyclinder off ebay? I've been Leary of buying those.
82' kz750 ltd.
  • mike0537
25 Apr 2013 11:59
#583964
531blackbanshee wrote: looks like you could use a rub strip on the front of that arm under the chain run.
I've got one on there! ;)
1980 KZ750E
  • mike0537
25 Apr 2013 12:01
#583965
Jrbrownie00 wrote: are those levers / master cyclinder off ebay? I've been Leary of buying those.
Brake master is from ebay. Clutch is stock
1980 KZ750E
