79 Z1000 ST "PROJECT NEW/OLDSKOOL"
- jarrad
Re: 79 Z1000 ST "PROJECT NEW/OLDSKOOL"
03 Jun 2013 06:02 - 03 Jun 2013 08:01
Cans turned up today, one is a bit banged up but I can cut and flip it and after a polish they should look top notch.
Just need to work out how to squeeze them under the seat.....
So to hide the dent and a few good scratches i flipped them left for right and both upside down, I will need to rotate the outlets 180deg so they pound down again
They will fit under the tail with about 1/3rd of the height hidden so I will put new decals on the side at the bottom.
"IF EVERYONE HAS ONE, I DONT WANT ONE"
79 z1000st BUILD:
www.streetfighters.com.au/for...-OLDSKOOL-quot
R6 build:
www.customfighters.com/forums...ad.php?t=53108
KDX build:
www.dirtrider.net/forums3/sho...d.php?t=166143
79 z1000st BUILD:
R6 build:
KDX build:
Last edit: 03 Jun 2013 08:01 by jarrad.
- jarrad
05 Jun 2013 06:53
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
05 Jun 2013 10:52
what is it called?
and,
where did you get it?
and,
- faffi
05 Jun 2013 18:40
Can you remove the rivets, take the shell off and have an expert take the bumps out from the inside, just like they remove parking dents of car doors?
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
- jarrad
05 Jun 2013 19:57 - 05 Jun 2013 20:04
No eBay APP ID and/or Cert ID defined in Kunena configurationLeon they are just called a motorcycle lift/jack
found one on eGay US for ya:
there only downside is the Min Height: 13" so i need to lift my bike onto it and they are only rated for 300lb but we know we can go more than that, however i wouldn't go this high on a full bike.
its a small price to pay for such a compact stand, much less bulky than a work bench and the bike is un-sprung too.
Faffi, the plan was always to cut the cans down so they would fit in the tail/ be really loud.......
they will end up being 295mm long and 2" straight through.
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
Last edit: 05 Jun 2013 20:04 by jarrad.
- jarrad
09 Jun 2013 02:30
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
- bluezbike
09 Jun 2013 14:18
.....but I thought you said if everybody has one you don't want one??? :laugh: .......but seriously now, I would dump the Kawasaki emblem and fab up a double row of LEDs in it's place tucked up under the seat rim all the way across. Those pipes look awesome!! :woohoo:
79 KZ 1000 LTD
- jarrad
09 Jun 2013 17:38
Haha sure there are undertail exhausts out there but I dont remember seein too many Zed's with
twin Rs3 Yoshi's poking out....
I was thinking the led idea maybe even lowering the pipes a bit if I had to.
Glad u like em!
Glad u like em!
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
- bluezbike
11 Jun 2013 23:46 - 11 Jun 2013 23:46
I was thinking of the rear stop light when I said what I did hahaha. Very cheeky, sorry. All you are doing looks really good....I bet that exhaust is going to sound like nothing on earth... :evil:
79 KZ 1000 LTD
Last edit: 11 Jun 2013 23:46 by bluezbike. Reason: typos
- Hollywoodmx
12 Jun 2013 10:51 - 12 Jun 2013 10:54
I dont think I would trust the stand with a full kz on it..
I like the led idea. Also I would put heat reflective tape (the good stuff from hot rod shops) on the inside of the tail section to reflect the muffler heat.
jarrad wrote: Leon they are just called a motorcycle lift/jack
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 12 Jun 2013 10:54 by Hollywoodmx.
- DesertKZ
12 Jun 2013 13:51
A small oval LED tail light/brake light like the one below (it's the one I use) would fit well where "KAWASAKI" is at. Just a suggestion.
www.cyclegear.com/CycleGear/Parts/Electr...-Light/p/38083_00000
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
1979 CX500C
1975 GT750 Smoker
- faffi
12 Jun 2013 16:14
You can also use red lens rear indicators with built-in brake- and tail light.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
