79 Z1000 ST "PROJECT NEW/OLDSKOOL"
- jarrad
Re: 79 Z1000 ST "PROJECT NEW/OLDSKOOL"
05 May 2013 23:41
moving along... i washed out all the little glass beads today, ran the hose through the oil galleries with simple green for a good 5 mins.
got the selectors in the new clean cases:
and got the bottom end tucked away:
"IF EVERYONE HAS ONE, I DONT WANT ONE"
79 z1000st BUILD:
www.streetfighters.com.au/for...-OLDSKOOL-quot
R6 build:
www.customfighters.com/forums...ad.php?t=53108
KDX build:
www.dirtrider.net/forums3/sho...d.php?t=166143
79 z1000st BUILD:
R6 build:
KDX build:
- faffi
06 May 2013 03:28
Looks clean
Wouldn't vapour blasting have been safer?
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
- jarrad
06 May 2013 08:12
Thanks mate, vapour would have been safer yes but nothing beats the finsh of aqua blasting!
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
- jarrad
11 May 2013 08:08
So I picked up Betsy the parts bich today (not really many parts left.....) I'm pretty happy with what I scored but also a little confused
Here she is:
It's got whats left of an 1100 donk:
And someone has welded in some bracing and a lower engine mount that as far as I know the Z1000ST never had
So could this be a GPZ motor? Coz they have the second lower front engine mount:
They have also done the bracing down the back bone, bounes!!!
And I got my cast engine mounts!!!!!
Here she is:
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
- floivanus
11 May 2013 11:45
Those braces almost look like the stock 81 and up frame braces, dash looks to be from that time frame to.
Somewhat different bike basically only the same as tha 80 and down bikes in name
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- faffi
11 May 2013 17:02
One could almost suspect it to be a 1981 KZ1100A, the bike that took over from the 1000ST. However, I have also heard that the 1980 version of the KZ1000ST had a rubber mounted engine, but have never had this verified.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
- jarrad
11 May 2013 18:36 - 11 May 2013 18:37
got a chance to check the compliance ptate this morning
and fafffi you are on the monet mate!
build date jan 81 KZ1100A Shaftie.
so now im thinking im thinking it would be a hell of a lot easier
to use this fram as it has all the bracing already in it
and the correct mounting points for my engine.
the frame is a lot worse than my original its straight but has a lot
of surface rust but im sure after a sandblast it would be fine.
any thoughts on the frame?
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
Last edit: 11 May 2013 18:37 by jarrad.
- faffi
11 May 2013 19:51 - 11 May 2013 19:51
It has more rake and trail than the J and R model if memory serves, but you can of course play with that by how far you raise the rear and how much offset you use on the triple clamps. I've forgotten what frame you will be using? I could check the figures of the ST and A and how they compare, but that will have to wait for another day.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
Last edit: 11 May 2013 19:51 by faffi.
- faffi
02 Jun 2013 18:26
So, jarrad, any new progress on the project?
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
- jarrad
03 Jun 2013 01:44 - 03 Jun 2013 01:47
yeah sorry guys been a bit slack lately....
this is the only reason i bought Betsy, to get these engine mounts, everything else was cream on the top:
Now she has been raped of all her parts:
inside a little milky but not too bad:
Spares all tucked away for later if needed:
Un-related but I put a new tyre on my 640 motard...... getting a little bit of rub!
Gasket kit arrived:
my new metal making device also arrived:
so i have started stripping down the frame to mount the mono shock:
so things are moving along slowly, its hard when you can only make noise when baby's are awake...
oh and got a awesome score on some twin Yoshies that i will now squeeze under the tail:
$66 bucks has to be a good score no matter what country you are in?
Gasket kit arrived:
79 z1000st BUILD:
R6 build:
KDX build:
79 z1000st BUILD:
R6 build:
KDX build:
Last edit: 03 Jun 2013 01:47 by jarrad.
- pappy750
03 Jun 2013 03:19
that back end looks so great man :ohmy:
- faffi
03 Jun 2013 03:30
Good to see things moving along
1977 KZ650B1
1980 F1 engine
B1 Points ignition
1980 F1 engine
B1 Points ignition
