HARRIS MAGNUM - Z1000
  • Pigford
  • Pigford's Avatar Topic Author
04 Feb 2012 16:04
#502017
My dream bike finally aquired.... Needs a fair bit of work - but "no pain, no gain" :dry:
Got it back in Oct 2011 - been quite busy with it - - - - - more to follow ;)
...should know better!
  • Zedone
  • Zedone's Avatar
Re: HARRIS MAGNUM - Z1000
04 Feb 2012 19:16
#502059
Wow! :woohoo: Great score, is the frame chrome moly or what type of material did they use back then. Those frames are getting pretty rare.
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • TexasKZ
  • TexasKZ's Avatar
04 Feb 2012 19:55
#502067
WOW! X2.
Looking forward to this build for sure.
  • nobody
  • nobody's Avatar
04 Feb 2012 20:23
#502071
:huh: dont know about this one but looks real cool would like to see moor as it goes on thanks
  • ultimate fighter
  • ultimate fighter's Avatar
05 Feb 2012 00:56
#502138
That's the next step in my kz build...stress the engine and make a nifty spondon style frame.
Way cool. Bet this thing will handle like a dream
love building motorcycles one headache at a time
  • Kitten Tooth
  • Kitten Tooth's Avatar
05 Feb 2012 02:27
#502157
im lovin' those huge ass disks on the front wheel. I like the swingarm too. That looks NNNIIIIIIIICCCCCCEEEEEEE B)
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • Pigford
05 Feb 2012 06:38 - 05 Feb 2012 06:40
#502172
Cheers chaps .....
The frame is a Magnum 1, built in Oct 1981 for a Z900/1000 motor.
Made of Reynolds 531 & T45 - hand brazed and pure lushness :evil:
I've sold off the Gixxer front end and the Ducati rear - everyone had a spate of fitting s/sided swingarms and I want this one looking a bit retro ;)
Managed to score a few "trinkets".....
None of it is a "straight fit" :dry: so some engineering work was needed by my local people.. www.talon-eng.co.uk/
Last edit: 05 Feb 2012 06:40 by Pigford.
  • Pigford
07 Feb 2012 15:43 - 07 Feb 2012 15:50
#502602
So, whats next - ahhhh yes..... I've had to get the lower rear motor lugs brazed back on and took the frame and swingarm to TALON for an estimate to trim 7mm off each side of the JMC & make a spindle sleeve - as the Harris spindle is 20mm & the needle bearings are 25mm :huh: They said it would be about a days work (setting up the machines takes a while) and £250 max. I could get it done a bit cheaper, but I want this work done right!!!
In the mean time I've made some card board templates of the lower rear engine mounts, to line up with the lugs..... I had some 10mm ally plate which I'll cut out for the brackets.
I also took Mr JigSaw to the Zed Butt unit & hacked a bit of fiberglass off....
The JMC is sitting ON the pivot in those shots and the rear end is sitting rather low.
I'll make some brackets and make sure the seat is nice and firm to support the rider :P
I dropped a few bits off to Mikey (the polisher) and took the cam cover off - so I could get my first glimpse of the motor internals....
..... as luck would have it, the top end looks good, the cams are mint and the clearances are spot on ;) As you can also see, the cam caps have the standard bolts fitted - so hopefully no surprises there!
I think I'll be doing the minimal mechanical work and just give it a thorough service, a bit of a clean up and run it
Last edit: 07 Feb 2012 15:50 by Pigford.
  • jeffasaki
  • jeffasaki's Avatar
07 Feb 2012 15:49
#502604
local people?
fucking rich ass poser
through money at it but use your own knowledge
and hands
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • Pigford
07 Feb 2012 15:53
#502605
jeffasaki wrote: local people?
and hands
I'll show you the engine brackets I'm making - then you'll understand :blink:
I build my own engines - but don't have any welding or machining equipment - and you may like using a bastard file to trim stuff- but I wanted it done right, not bodged. ;)
  • jeffasaki
07 Feb 2012 15:59
#502607
i only use a half round crosscut mill bastard
if i have to
in the correct hands
they are very effective
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
07 Feb 2012 16:18
#502613
At first i wondered why u would remove such a cool SSSA .
but after seeing plan b, i thought, OHHH YAAAA!! B)
u just cant find a nicer looking arm than a JMC. SOOOO SWEET .
This is going to be a winner. :)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
