Let's Get This S*** Started!
- seanbarney41
- '79 kz1000 LTD '75 Honda CB750
Re: Let's Get This S*** Started!
23 Oct 2010 15:17Please Log in or Create an account to join the conversation.
- seanbarney41
23 Oct 2010 15:20Please Log in or Create an account to join the conversation.
- seanbarney41
23 Oct 2010 15:25
Well, that's it for now. I got ignition coils on the way. Next step will be a compression test as I havn't done that yet. Hope my broke azz slow progress doesn't drive you guys crazy. Thanks to all for knowledge and info.
- DoubleDub
23 Oct 2010 15:27
seanbarney41 wrote:
I'm going to guess and say "yep".
- TeK9iNe
- What did you do!?!
23 Oct 2010 15:29
UHHHH.... Im gonna go out on a limb here and just say that someone has deffinately beat the shit out of this motor.
Before you start doing enything else... GET A SERVICE MANUAL.
...get a compression guage on the engine, and determine the condition of it first. You could be spending well into the $1000 + range, just to freshen up a beat to crap motor.
Starting with all the other crap is not necessary.
Rust is not a good indicator for engine internals... :dry:
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
23 Oct 2010 15:32
seanbarney41 wrote:
Ignition coils on the way... :blink: Have you checked the condition of the origional coils? Plug wires/plug caps, plugs, wiring, points/pickups, condensors...?
Don;t get too far ahead of yourself or you'll be dumping $$$$ for no reason.
:silly:
:silly:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- seanbarney41
23 Oct 2010 15:34
Tek9ine, I agree with what you are saying but I am not sure where you are seeing rusty engine internals?
- seanbarney41
23 Oct 2010 15:37
Yeah, stock coils tested bad when I first got the bike plus they are cracked, leaking, and attached cables are barely attached.
- trianglelaguna
23 Oct 2010 15:54
get a cheap dyna s and some good condition used coils as time and winter and paydays allow...i got a dyna and a harness for 30 once,.....
you may have a big bore...and i don't think most folks get the bike.or keep the bike running long enough to hurt the greater majority of these things...i have raised many idiot owned kz's that were on the verge of a tow away from the fools ashes and ridden them hard as hell once gotten on the rode...and never had one of probably 10-15 fail ...it takes a water in the motor season or a fire to put a Z down...think positive
and stay on target...the more pics is see the more i like...you def got something to work with......you may even have a neglected ripper in the rough there....go tight and go right and shoot for clean work and clean finishes on the little stuff ,do like guys here and get one thing right ,clean,no matter the expense to a point,and the big picture shines nice in the end every time..it's only money and you got a muscle bike head turner, before you know it....you wont regret getting the correct stuff in the end imo.good thoughts your way
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- seanbarney41
23 Oct 2010 16:11
Yep, thats pretty much the plan. Once the compression checks, it's time to get some spark goin'. May have been foolish to order coils first but they were pretty cheap and I had the money. Hopefully the fuel system is just gonna be time consuming and not expensive. Then I can get the thing started and better assess where I'm at. Yeah Tek9ine, I'm well aware of the cost of a motor rebuild. That's why I'm gonna check stuff before money gets spent on other equipement.
- DoubleDub
23 Oct 2010 17:08
Sounds like you have a good path laid out in front of you. Keep the pics coming!
- Old Man Rock
23 Oct 2010 17:27
Almost forgot....
A good 90% of the Z1, KZ900, 77/78kZ100 are all the same in design... Sure there are some differences here and there but this will help you out tremendously....
Download, read & study....
kzrider.com/index.php?option=com_docman&...d&gid=434&Itemid=108
And take a whole crap load of images before taking stuff apart for you WILL forget by the time you get back to it....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
