Tri.... scores one for the barn find column 79MK11
- trianglelaguna
Re: MK11 and ST...same body parts.???
12 Apr 2010 16:05
thanks...tony
got the manual today...kz1000...but with 120 pgs for 79-80 supplement......good night shift reading...dynas and a seat cover next...bars ....and then valves and carbs and see if it is tad better...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Tony
Author
12 Apr 2010 19:17
I would do some research on the coils before you buy new ones. In the dyna literature, I read you can remove the ballast resistor and use 3 ohm coils. So if you have a decent set of 3 ohm coils get rid of the ballast resistor and use them. I will try and find that info for you.
- trianglelaguna
13 Apr 2010 00:44 - 13 Apr 2010 00:47
i was just gonna get a set of green 3 ohm dynas...are those the 3 ohm you refer to?
i have extra mismatch coils laying around but figured on just buying dynas and removing the balast as you note...seems the stock ic ignitor and elec ignition will work fine with the dynas ....it is almost a tie trying to buy stock 79 coils or used dyna greens -as it is to just get a new set of dyna 3 ohm greens on an auction sale...
thanks for all your help.....time to clean and organize the shop and see where i'm at...i got stuff piled and messed pretty good....no fun working on bike when it's not organized imo....
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
Last edit: 13 Apr 2010 00:47 by trianglelaguna.
- Tony
Author
13 Apr 2010 19:08
Craig, It looks like when I merged the two together it places all the posts by date so some of the posts are out of order. If you don't like it let me know and I'll put it back the way it was.
- trianglelaguna
Re: Tri.... scores one for the barn find column 79MK11
14 Apr 2010 02:24 - 14 Apr 2010 02:27
thanks Tony,
this'l be my build thread so move it/merge it, it's all good....
gonna get the bike on the bench saturday and see what ignition sytem it has under the timing cover ,and try and do the valves and carbs too....i may try and put the bowls from a set of extra kz900 26mm on the pumpers and eliminmate the pumer circuits.....we'll see ...may not need to...also i wanna check and see if it will electric start with the headlight fuse taken out, if it still wont crank start after the carbs and valves...it may need a fresh battery.....i wish i could just put an earlier kz1000 right throttle swith housing and get back to having a headlight switch.......anybody done this to full time headlighted kz before?
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
Last edit: 14 Apr 2010 02:27 by trianglelaguna.
- trianglelaguna
14 Apr 2010 19:04 - 14 Apr 2010 19:04
here is a friends MKII...sweet..it is blue now...guy is a great painter......i'm painting mine black but gold and thin white on my pinstripes
click on photo to enlarge...
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
Last edit: 14 Apr 2010 19:04 by trianglelaguna.
- keith1
15 Apr 2010 03:12
trianglelaguna wrote:
is that a cravenmobile?
- trianglelaguna
15 Apr 2010 05:36
nope i believe that's willy's bike!!!!
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- trianglelaguna
15 Apr 2010 05:36
who's craven?:huh:
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- trianglelaguna
16 Apr 2010 09:08
anyone ever used or checked into these newer type dyna 3 ohm coils...seems to be okay for me to run right?
I'm going with a new set anyways...wether i go "green" dynas or thses should not matter aye?
Product: COILS
Description: DYNA COIL 3 OHM
Additional information: 3 OHM; DUAL TOWER COIL; DUAL FIRE; SINGLE PLUG (EA.)
Manufacturer`s #: DC13
One of the smallest packages delivers high output with advanced magnetic core technology Designed for use with Dyna 2000 and 3000 series ignitions; factory-installed electronics; or with aftermarket ignitions that employ dwell control Secondary resistance is 11.5 ohms Great for customs where coils need to be hidden
Product: COILS
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- 79MKII
- Love Them Kaws!
16 Apr 2010 10:05 - 16 Apr 2010 10:06
It's all about the ohms. Specific ignitions can only handle so much current, so the coils you put on there can burn out the igition. I can't remember for sure, so don't quote me, but I think the stock electronic ignition needs at least 3 ohms to be safe. The stock coils are less, so the resistor is added. When you replace the coils with higher ohm units, the resistor can be removed.
I like those new coils - I was just too afraid to try something so new - I don't know anyone that has used them.
Product: COILS
The Kaw List:
Last edit: 16 Apr 2010 10:06 by 79MKII.
- porchev914
16 Apr 2010 11:26
I almost bought those coils instead of the dyna greens, then realized they wouldn't work with a dyna S. If the 79 is factory electronic ignition, it should work for you......hell, who am I kidding, I don't know! :ohmy:
FRANKEN Z!
