Tri.... scores one for the barn find column 79MK11
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: MK11 and ST...same body parts.???
22 Mar 2010 06:06
#355357
virtually nothing interchanges between the two.they look almost the same but that is it
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
22 Mar 2010 06:38
#355360
trianglelaguna wrote:
are the inner eninge parts the same on the mk11
and the mk11 ltd's..mk11 z1r's?
or does the ltd with the mk11 look have a different crank ect....
thanks guys craig
Hello Craig...most of the external stuff is unique to the E models and doesn't translate well to the A models. However, some of the internal motor stuff is shared with the Z1R (D3), E, and G models...for example the crank is shared with the above but not, apparently, with the B models...but, according to Mother Kaw, B shares a crank with the C2/3/4 models. You are going to have to go through the parts list to see which models share what, internally.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Jack
  • Jack's Avatar
22 Mar 2010 07:09
#355365
Craig, I have a right side ST sidecover on my street MKll.Two of the mounting pins will line up on the top but the bottom one doesn't. I just drilled a very tiny hole and zip tied it in place. You have to look hard to notice it but the profile of the ST cover is quite different from the MKll.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • keith1
  • keith1's Avatar
Re: Tri.... scores one for the barn find column 79MK11
22 Mar 2010 07:23
#355366
just reading this now.....lucky bastid...great score...B)
  • Old Man Rock
  • Old Man Rock's Avatar
22 Mar 2010 08:22
#355383
37" Wheels....:blink: Throw in some bling and light kits and Craig-Pimp-Daddy may go for it TB.... :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • trianglelaguna
  • trianglelaguna's Avatar Topic Author
22 Mar 2010 09:38
#355400
okay thanks...arai said the right would work from an st...the ones i see on e-bay are bumped in profile ,so i think i get what your saying.......where can i get an aftermarket MK11 right cover...anyone???
the st fender i have may not be the same ...the one on theres ok but has the little scrape mark they get from small front slides....
i will check the frame and engine numbers and go into some research...thanks guys....
i did see seat covers from suppliers listed as MK11...we'll see...i need to try and start a tie in with a local upholstery person anyway.........
a link to where to get right sidecover for MK11 would be great though!!!!
peace craig
p.s i just used an old rag and some mothers on the still dust covered clutch...for just one wipe and polish swipe...it is gonna be a good bike soon....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • trianglelaguna
22 Mar 2010 09:48
#355402
This is the best site ever....a member just hooked me up....
remove side cover from my parts checklist!!!
Thank you to the member also....YOU ROCK HARD!!!!
there my day is good agian......
someone once had me read a page from a little book he had ....i was really down and getting divorced ...drunk...ect...it said
"karma can change like the swish of a horses tail"
it just was what i needed to hear right at that exact moment...kinda free'd me up to try again......
like my day just doing a 180...good stuff...
1976 KZ900
2003 ZX12R
2007 FZ1000
  • 2bskor
  • 2bskor's Avatar
28 Mar 2010 04:52
#356674
I have an ST and they are wired ducks!! I suggest going to kawasaki.com/DefaultFrame.aspx?strConten.../VICHOOSEVEHICLE.ASP Then select your bike ans look at the parts diagram and compare part #'s for the parts from your bike vs the ST.
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
  • trianglelaguna
28 Mar 2010 07:25 - 28 Mar 2010 07:59
#356684
well the cover arrived and even has the emblem....gonna go black gold like eddies early racer MK11....
thanks you to the member for the total unselfish act and for helping my bike on it's way......
building a cycle bench today...may get the bike on there by p.m and pull the carbs....looking for a can for the kerker...
i have a V&H chrome street standard pipe..brand new and may use it for now.....seat cover on the way too...
1976 KZ900
2003 ZX12R
2007 FZ1000
Last edit: 28 Mar 2010 07:59 by trianglelaguna.
  • trianglelaguna
28 Mar 2010 08:01 - 28 Mar 2010 08:03
#356693
got a brad new set off tarozzi ,italian, aluminum rearsets sitting in a drawer, because i never went to a disk rear on the 900...looked at the hole pattern -held em next to MK11 pegs/fame,huston we have lift off....set backs are really nice material/finish...we'll see....
1976 KZ900
2003 ZX12R
2007 FZ1000
Last edit: 28 Mar 2010 08:03 by trianglelaguna.
  • trianglelaguna
28 Mar 2010 09:13
#356708
does anyone know if "ATK" still makes fork braces??
they have the look i want to match...going with gold and silver aluminum finishes for the MKII and want an aluminum fork brace...the tarozzi braces may not work with chrome fenders.....
the below picture shows the tribute colors and mods-sticker/placement i will be trying for on my MKII
1976 KZ900
2003 ZX12R
2007 FZ1000
  • otakar
  • otakar's Avatar
28 Mar 2010 09:24
#356710
About the only fork braces you will find for these older bikes are "Tarozzi"
www.tarozzipaolo.com/indexplo.htm
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
