'78 KZ1000 makeover
  • porchev914
  • porchev914's Avatar Topic Author
Re: '78 KZ1000 makeover
05 Oct 2010 18:20
#404351
PLUMMEN wrote:
i wish i knew how to draw pictures on a computer! :( :laugh:
I wish you did too!! :laugh: But I think I got the gist of your explanation
FRANKEN Z!
  • PLUMMEN
  • PLUMMEN's Avatar
05 Oct 2010 18:25
#404354
got a fax machine? ill send ya a picture of what im thinking here! :laugh:
  • porchev914
05 Oct 2010 18:35
#404358
I did, until it freaked out on me last month. Now it tells me I have print cartridge error...with a new cartridge :angry: I think it's time for a new unit. I swear, they build this crap to be throw away junk. Nothing lasts anymore :(
FRANKEN Z!
  • PLUMMEN
  • PLUMMEN's Avatar
05 Oct 2010 18:39
#404360
thats the one piece of equipt ive had for more than 6-7 years,brother intellifax 775.
ive had 5-6 computers in same amount of time! :S :woohoo:
  • testarossa
  • testarossa's Avatar
05 Oct 2010 19:13
#404372
porchev914 wrote:
OK, I'm going to put it to a vote. The tongue n' groove joint on the left.....the lap loint on the right. Which is better and why?
Of these two I would vote for the one on the right. The thicker plates will distribute the load over a larger surface area on the bolt. I could see those thinner side plates cutting into the bolt over time due to vibration. Obviously use grade 8 or 12.9 metric bolts, and I would like to see loctite, or lock washers, or safety wired. Unless you want an ejector seat. :ohmy:
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • porchev914
05 Oct 2010 19:19
#404375
All 4 of the subframe bolts will be safety wired ;) The subframe bolts on my YZF all have lock nuts, so it's kinda important those bolts stay put :laugh:
FRANKEN Z!
  • testarossa
05 Oct 2010 19:31
#404376
I figured that you if anyone would know of the dangers of self loosening fasteners. You ought to see what fanatics the NASA boys are about fasteners.
2004 ZX-10R
Angola, IN
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
06 Oct 2010 07:07
#404443
my vote is for one triangle shaped piece that slides inside a clevis.like this one
perhaps :) .
simple clean,all the weight is in shear.so it is strong and lite.
p.s. the shoulder is healing up well not sure if i can take the ak's recoil yet but i am ready to try.:)
  • 531blackbanshee
  • Vendor
  • Vendor
06 Oct 2010 07:16
#404445
you pickin up what i am putting down.
the same place also sells threaded tubing ends that a feller at home could just weld right in.all profesional like.
  • 531blackbanshee
  • Vendor
  • Vendor
06 Oct 2010 07:19
#404446
  • porchev914
06 Oct 2010 23:23
#404770
Very nice idea Leon. The biggest problem I have is the lack of room. I could make more room, but at the expense of having to mod/relocate 2 more sidecover mounts :S At this point I think I'll leave it alone with the 3/8" brackets until I can get the bike back together and running. After the bike is whole and running, it'll be side project #2 to design and fabricate a carbon subframe. Side project #1 is to collaborate with OMR and make a hand bent stainless header. I haven't told him yet though, so you guys need to keep it a secret until I can take him to dinner and pop the question :silly: I'm pretty sure he doesn't read any of my threads, so he shoulnd't learn of my plot any time soon.
I should have saved the carbon body work as a side project after I got the bike back together, but I'm having too much fun being broke and learning :woohoo:
Those tubing ends and clevis pins would be perfect though ;)
FRANKEN Z!
  • 531blackbanshee
  • Vendor
  • Vendor
07 Oct 2010 06:42
#404815
that is how we mount custom sub-frames on quads,clevis on top,heim on bottom.wish i was closer i could sure help you out on that deal.
