1966 Kawasaki A1 Samurai restoration project
  • clutch
  • clutch's Avatar Topic Author
  • I wish I had a tad more patience to do it better!
Re: 1966 Kawasaki A1 Samurai restoration project
21 Nov 2011 03:15
#489428
Kidkawie wrote: Yeah, that early they may still have been using straight pipes.
I found an article on the Kawasaki Triples talking about adding expansion chambers to boost performance. I'm guessing if they didn't have them, then the A1/A7's probably didn't either. I may still go with those straight mufflers I found (kinda like that side-exit look :) )
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
  • clutch
21 Nov 2011 20:33
#489559
Alright. Got the crank cases just about ready to go back together, so I opened up my gasket kit to hunt down the crank gaskets. Wouldn't you know it...there aren't any! This thing has everything else...even exhaust gaskets. So...I need to use something, and was wondering what you guys thought about just a thin layer of red rtv as a gasket, rather than making a paper one?
Wish List:
  • loudhvx
  • loudhvx's Avatar
22 Nov 2011 01:42
#489640
I'm not a big fan of RTV in the crankcase.
I would use the rubberized gasket material. I think it's a little better than the plain paper stuff.
  • clutch
22 Nov 2011 01:45
#489642
loudhvx wrote: I'm not a big fan of RTV in the crankcase.
Is the RTV known to break down and cause problems? I was just leaning that way because it will be easier to make a gasket with that, than with the sheet gasket material (I admit, I'm a little lazy lol).
Wish List:
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
22 Nov 2011 04:41 - 13 Feb 2012 17:45
#489661
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 17:45 by KZ250LTD.
22 Nov 2011 09:49
#489677
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
22 Nov 2011 11:04
#489686
if you are talking about sealing the upper and lower case.
that only uses a sealer like the threebond patton linked to.
a paper gasket would not be a good deal there.the way the cases clamp the bearing races a gasket would affect the torque.
  • clutch
22 Nov 2011 13:00
#489697
Cool thanks for the info guys. This may seem like a silly question, but since this is my first crank case reassembly, I am unsure. Do I need to put the sealant only on the flat mating parts of the case, or also in the dips where the shaft bearings sit as well? Here's a pic with them circled (but the crankshaft is not...
Wish List:
  • 531blackbanshee
  • Vendor
  • Vendor
22 Nov 2011 13:34
#489702
only on the flat mating surfaces.
not in the bearing bores.
you just want a very thin coat of sealer.
think about when you tighten it down you don't want big globs oozing out inside where they can muck up stuff.
the nice thing about the threebond products is what does ooze out will bond inside the cases.where as silicone globs would be more apt to come loose and plug up something important.
  • clutch
22 Nov 2011 16:30
#489719
Ok. I had a feeling that would be a no, since I only found left over material on the flat parts. I tried to find three bond locally, but it looks like I will be ordering from Z1 since I had no luck. I will be working on cleaning up the engine covers until then. I started on one of the carb covers since I figured that would be the biggest PITA because of the kawasaki lettering stamped into them. The rest should be slightly easier, even though a couple are bigger.
I picked up some of that blue magic metal polish the other day and spent about 30 secs on a small section of one of the wheels. It looks like that stuff will do the trick for shining back up the wheels, spokes, brakes, and engine covers. I will hold off on using the polish until everything is back together, since I tend to get grease and grime on parts when reinstalling them. :)
Wish List:
  • clutch
22 Nov 2011 22:21
#489765
Z1 Enterprises is on the ball (as usual). I got a shipping notification 25 minutes after placing my order today. If the mail runs smoothly (LOL), I should be putting the crankcase back together, and back in the bike Saturday! :)
Wish List:
  • Saiph
  • Saiph's Avatar
  • 隼
23 Nov 2011 17:05
#489865
How much did you pay for yours?
1967 Kawasaki A1 Samurai
1980 Honda 750 custom
1976 Yamaha 650 special
1982 Honda 900
If it has two wheels I like it!!!!
