Pen's Z1
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Pen's Z1
29 Apr 2009 04:18
#286158
How are you setting up the fork stops? I'm just curious as I still have to do that on my front end and I have an idea but was curious what your solution is.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • irishwill
  • irishwill's Avatar Topic Author
Re: Pen's Z1
29 Apr 2009 06:34 - 29 Apr 2009 06:35
#286181
Later, Doug
they will be a bolt in deal Doug...that way you should be able to locate them where you need to regardless of the year of bike or style of "stock" stops.
what is you idea?
Last edit: 29 Apr 2009 06:35 by irishwill.
  • timebomb33
  • timebomb33's Avatar
Re: Pen's Z1
29 Apr 2009 06:37
#286183
ben those are real pretty buddy nice job as usal,god i'm gonna stop now i can't spell this morning anyway awesome job
I THINK MY POWERBAND BROKE
  • StreetfighterKz
Re: Pen's Z1
29 Apr 2009 09:10 - 29 Apr 2009 09:12
#286206
I have a Gsxr style steering damper on my bike. The mounting bolt is setup in the middle and close to the bottom of the steering neck. My thought was to run a spacer and slightly longer bolt to act as the frame stop. On the bottom clamp I'll have some stops welded on to go up against the bolt/spacer. That way the bolt will serve two purposes.
The stock nub on the backside of the steering neck had to be removed as the thicker aluminum Gsxr lower clamp interfered with it.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 29 Apr 2009 09:12 by StreetfighterKz.
  • irishwill
Re: Pen's Z1
29 Apr 2009 09:22
#286207
Here is what I did in the past on the '73.
I cut the stock stop off the frame and decided to use the stops on the bottom tree and mod the frame stops....so I just welded a couple of boss' onto the neck...it works well...
however on this one I wanted to keep the stock tabs ( not everyone has the ability /access to a welder).
so I figured if i could come up with a "stud" of sorts....drill and tap where it needs to be on the bottom clamp...it would be more universal.
I thought about keeping the stock dampner ....it looks cool on your set up....
  • StreetfighterKz
Re: Pen's Z1
29 Apr 2009 09:37 - 29 Apr 2009 09:39
#286212
I was going to do stops something like you had but from my photo you can see that the stops on the clamp are too far away from the neck to do that properly. Anyways here's what the stabilizer setup looks like with a 8" Gs headlight mounted. Don't mind the huge fork clamps I'm not going to use those.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 29 Apr 2009 09:39 by StreetfighterKz.
  • irishwill
Re: Pen's Z1
29 Apr 2009 10:39
#286222
very cool...I'm diggin' the "skeleton" headlight brackets.
  • StreetfighterKz
Re: Pen's Z1
29 Apr 2009 12:25
#286245
I actually stole the idea from some of the newer LTD's. I wanted something different, from the normal clamp/plate setup normally found in the aftermarket, and something lightweight so that's what I came up with.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • irishwill
Re: Pen's Z1
29 Apr 2009 16:47 - 29 Apr 2009 16:49
#286340
if this was star wars he'd be yoda...meet Mr. Shaw everybody...demon rebel machinist extrodinaire!!!
Last edit: 29 Apr 2009 16:49 by irishwill.
  • irishwill
Re: Pen's Z1
29 Apr 2009 16:49
#286341
  • irishwill
Re: Pen's Z1
29 Apr 2009 16:52 - 29 Apr 2009 16:55
#286342
A couple of pics to wet yer whistle...
the triple trees are basically a wrap...just a small ajustment to the stem (needs to be 3/8ths shorter)
and then off to the anodizer.
Last edit: 29 Apr 2009 16:55 by irishwill.
  • irishwill
Re: Pen's Z1
29 Apr 2009 16:58
#286348
another of the whole bike....the plate that you see all cockeyed there on the bike is yours bomber....just checking it to make sure its gonna work.
anyways we should have 10 sets of these ready to go in about a week to ten days....
they will come anodised or raw aluminum.
i'll keep ya posted...stay tuned
