77 KZ1000 resurrection
  • toecutter1974
  • toecutter1974's Avatar Topic Author
01 Mar 2009 06:11
#268869
Picked up this 77 KZ for $1,100.00 (with some trading and wheeling and dealing) 20,600 miles on odo. Here are the pics of how she looked when I got her home...
  • toecutter1974
Re: 77 KZ1000 resurrection
01 Mar 2009 06:12
#268870
more pics
  • toecutter1974
01 Mar 2009 06:14
#268871
yet another
  • toecutter1974
01 Mar 2009 06:17
#268875
and another... Already pulled the carbs, and I am replacing all gaskets and giving them a good scrub. Pulled the tank (to coat the inside) and tail piece. Removed rear wheel to check bearings and clean/replace chain and clean sprockets. Now as a newbie to the KZs is this gas tank really held on by that little rubber bungee by the front of the seat?!?
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
01 Mar 2009 06:33 - 30 Mar 2009 03:45
#268883
It will look a lot better with a day of cleaning. The scarred engine covers can be replaced and that will help a lot. I'd say good buy. Roy
Last edit: 30 Mar 2009 03:45 by roy-b-boy-b.
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
01 Mar 2009 07:06
#268894
Yep that is how they are held down from the factory. That bike looks like a pretty good basis for a project. Do you know what direction you intend to go with it? I've got a 77 LTD 1000 here with similar mileage I'm trying to figure out what I want to do with.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • Locozuna
  • Locozuna's Avatar
01 Mar 2009 08:07
#268907
I was told that the thought was to let the tank separate from the bike and you if you went down. No use having a tank filled with gas between your legs or spilling out on you or a hot engine. Also better isolates the tank from hard points and needless vibration and shock. Sounds reasonable to me.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • timebomb33
  • timebomb33's Avatar
01 Mar 2009 08:08
#268908
make it go fast
I THINK MY POWERBAND BROKE
  • toecutter1974
01 Mar 2009 08:18
#268911
My plan is to keep the bike as stock in appearance as possible, but eventually big bore, bigger carbs, probably replace the ignition system. So looking to create a bit of a sleeper... For now, give the bike a good once over, and get ready to ride this summer!
  • toecutter1974
05 Mar 2009 11:30
#269835
Anyone run a clubman style bar on one of these badboys? I'm wondering if I will encounter clerance problems with the tank...
  • timebomb33
05 Mar 2009 12:23
#269840
yes you can run into problems with clip on's with a straight drag bar you will have problems as well, that is why most guy's use the super bike bar instead
  • Old Man Rock
  • Old Man Rock's Avatar
05 Mar 2009 14:50
#269864
And no oil leaks around the cylinder/head, seems clean....
As mentioned, a day of cleaning, removing some rust, buffing of the engine cases, down the road some paint and this bike would look sweet indeed...
Seems like a hell of a deal for $1100....
How she run?
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
