77 KZ1000 resurrection
- toecutter1974
Re: 77 KZ1000 resurrection
05 Mar 2009 16:24
right now she runs pretty quietly.... she's in about a hundred pieces in my garage! Actually ran OK, carbs were ilthy and way out of sync. some a-hole used like two tubes of gasket maker around the headers, tail light was held on by two bent pieces of metal screwed to inner fender, it looked like she was still running on the first oil change! and there is a little seepage around the head gasket... all of this will be remedied soon and I'll post some pics along the way. You guys have been very helpful so far!
- toecutter1974
- toecutter1974
06 Mar 2009 05:10Please Log in or Create an account to join the conversation.
- toecutter1974
06 Mar 2009 05:11Please Log in or Create an account to join the conversation.
- PLUMMEN
06 Mar 2009 05:30
- donthekawguy
09 Mar 2009 00:46
toecutter1974 wrote:
Those mount on the side of the battery box in the stock position.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- toecutter1974
18 Mar 2009 19:59
home stretch... took her out for the maiden voyage (carbs were way out of synch... pulls pretty hard!
- toecutter1974
18 Mar 2009 20:01
I still need to clean up the rear wheel, re-paint the side covers and mount the rear directionals...
- toecutter1974
18 Mar 2009 20:02
she is a bit smoky at startup and the electrics definately have a few gremlins, but hopefully I can log some miles when the weather breaks...
- toecutter1974
18 Mar 2009 20:04
A lot more cleaning and rust removal on the small bits... had to make this bracket, the guy that I bought it from had a piece of heavy rubber as the exhaust hanger...
- toecutter1974
19 Mar 2009 16:50
OK, so the bike runs... but not well. I am thinking that she is a bit lean because of the pods and free flow exhaust... Anyone have a good jet combo to run with this set up before I synch the carbs?
- arai59
19 Mar 2009 16:59
Are those Emgo pods ? If so, they are crap for filtration and pull way to much air which tends to surge at highway speed. What pilots and mains are you using? And what size carb exactly is it ?
