Z1 900 making my dads old bike look new *now Pics*
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
Re: Z1 900 making my dads old bike look new *now Pics*
05 Feb 2009 20:16
#262451
Finally got the head off, dosent look to bad for being 35 years old and having around 40,000 miles.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • oldkaws4ever
05 Feb 2009 20:20
#262454
Cylinders 3 & 4, not bad normal carbon build up, it should clean up nicely with seafoam and gasoline.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • oldkaws4ever
05 Feb 2009 20:22
#262455
Cylinders 1 & 2, not bad either normal carbon, should clean up nice.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • oldkaws4ever
05 Feb 2009 20:26
#262459
And here is a hot with the front mag wheel mounted, the wheels definatly change the look and feel of the bike for the better i think..........that is until i can come up with the funds to send my wheels to buchanon's for new spokes and such..............ah one day hopefully.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • oldkaws4ever
05 Feb 2009 20:31 - 05 Feb 2009 20:48
#262461
Well i also found out the front fork sprinks are kissed, because the bike dosent have any spring in the front end and they are below the service wear measurment, so some nice new progressive fork springs, fork seals and dust covers are in order fom jeff at Z1. I also have to order my comlete engine gasket kit...........does anybody know if the complete engine gasket set is the same for the kz 900?, because there is one on e-bay right now. Im also going to get a brand new wiring harness.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Last edit: 05 Feb 2009 20:48 by oldkaws4ever.
  • oldkaws4ever
06 Feb 2009 20:24
#262654
I wan't to get that crappy black chipped paint off the motor. Any ideas on how to go about that task? I was thinking carb spray cleaner and a scotch brite pad?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • CRO DOG
  • CRO DOG's Avatar
06 Feb 2009 22:45
#262666
oven cleaner?
1975 z1 with many custom parts. Built by EPE performance cycles.
Chicago, Il
  • Hogslayer
  • Hogslayer's Avatar
  • PUFF DADDY
07 Feb 2009 10:25 - 07 Feb 2009 10:29
#262738
I have always used auto paint stripper. Wear gloves and rinse parts with soapy water then blow dry.You then could bead blast or soda blast them. They will look better than new!
Last edit: 07 Feb 2009 10:29 by Hogslayer.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
07 Feb 2009 10:58
#262741
Andrews 4x cams are .430" lift 286* duration. those are to0 much for a stock head and require shim under buckets and clearancing so the lobes dont hit the head. I have similar cams in my head.I have the spec sheet. i can email it to u if u need it.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • trianglelaguna
  • trianglelaguna's Avatar
07 Feb 2009 11:14
#262743
i used paint stripper gel...rubber gloves and a tub to catch the parts cleaner and excess and re-dip my plastic bristled brush and toothbrusnhes and the covers i did are perfect now the .po ..had layers on layers... i had to re-strip alot.......after some polishing they are 100% better.....i think i'm gonna wait till the kz motors out and the z-1 is in it to strip and pressure wash the kz the same way....good luck...i'km jealous of your parts list...those guys are awesome at z-1.....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • otakar
  • otakar's Avatar
07 Feb 2009 11:20
#262744
Don't use anything that will harm the Aluminum. I buy the Zep Citrus cleaner at Home Depot and use it on my whole engine. It cleaned out my combustion chambers like they were new. If it is the stock engine paint that came on the bike, the only thing I would use would be Aviation grade Paint stripper which is designed for aluminum and is one of the few things that will take it off. I however find that throwing the entire head in the Citrus cleaner and letting it soak for as long as it takes works wonders.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • oldkaws4ever
07 Feb 2009 19:09
#262805
Ya i seen the aviation grade stripper at walmart the other day. I will have to get over there soon and get some. I will post some pics when i get the paint off. Otakar i have seen that Zep citrus cleaner at home depot, but was hesitant to get it because i didn't know how it would work. I will pick some up the next time im in there. Can i put the whole head in the Zep cleaner? Or do i have to dissasemble it?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
