KZR750R1
- kzr750r1
Re: KZR750R1
21 Mar 2021 06:59
All back together with some new tires. Feels much better having a crown on the rear again.
Bridgestone were old and rear was plugged. Michelin's feel good so far, was lucky to find this set.
Brakes were serviced. Rear caliper sliders dry, greased up. All is well.
Now I can get back to the ZRX.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- ThatGPzGuy
Re: KZR750R1
21 Mar 2021 09:00
Looking Good
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: kzr750r1
- kzr750r1
Re: KZR750R1
19 Apr 2021 16:13
RS34 puked last restart. Just finished a fork refresh, installed new clutch plates and oil change.
So figured it's time for a rebuild of the BS34 and RS34.
Looking for the size of the unobtanium PN 92055-510 so I can source them by size and material. One of the members posted having them but being in Sweden and not knowing how often he visits may take a bit. Have the internal o rings and base gaskets on order from Partzilla.
Sudco just sold me the RS34 rebuild kit that includes the crossover o rings. I will be able to proceed with those first.
Shame cause the BS are blown apart already.
- scubaanders
Re: KZR750R1
19 Apr 2021 21:58
PM sent.
/A
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
- kzr750r1
Re: KZR750R1
20 Apr 2021 06:42
The following user(s) said Thank You: scubaanders
- scubaanders
Re: KZR750R1
21 Apr 2021 05:20
KZR750R1
You have now a package of Scandinavian goodies comming your way.
Brgds Anders
Brgds Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
The following user(s) said Thank You: kzr750r1, slayer61
- kzr750r1
Re: KZR750R1
10 May 2021 16:46
Arrived thanks for the O Rings Anders!
- scubaanders
Re: KZR750R1
11 May 2021 06:28
Always nice to be of service!Fun thing MartyZ1000 dropped by my office today and bought a refurbished petcock from me . Got his old petcock as a trade in, it was a sorry sight.
So now servicing KZRider members both far and near.//A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
- kzr750r1
Re: KZR750R1
11 May 2021 18:04
Well the continuing saga here.
RS34 clean up is complete. Setup is tamer with some adjustments to the accelerator pump. It was coming on a bit too soon for the jetting. Will be making some more micro adjustments once I take care of the driveline...
The initial goal for this bike was to be modernized. 17” rims, wider tires updated suspension bla bla bla... then life took over.
output sprocket was setup to be flipped in the future and supported by a carrier bearing. None of this is going to happen.
Due to the fact the kz and zephyr have different length output shafts it’s going g to take some measuring to get the back space right.
Found a 530 chain makes it more fun. Located a new flat 16t front sprocket and it should fit the bill. Likely need to have a spacer to clear the splines when the chain is aligned.
Keeping it running is the goal at the moment. So now this is my challange... link the go shaft to the ground!
bs34 Carb rebuild can start now thanks to anders. This will tame the beast in town some.
- kzr750r1
Re: KZR750R1
04 Sep 2021 01:50
Have been riding a little this summer and working mostly on other projects.
Front gear working.
Finally, by the hands of Motolab and my internet luck finally put the BS34 back on the bike,
Fuel feed bits were perfect with his spec orings. JBM Industries diaphragms seem to fit well.
Float level test in the am.
No leak I'm hitting the starter..
Front gear working.
- kzr750r1
Re: KZR750R1
04 Sep 2021 15:01
Well got the carbs to hold gas and can't start it. Starter clutch is just done.
Looks like I can get it replaced without splitting the case... But still a lot of work.
May need to shelve this till I get the ZRX done.
- azman857
Re: KZR750R1
04 Sep 2021 15:47
NAHHH. Just get a ZR-7 starter clutch and swap that in. Sure you gotta rip both side covers off the engine and take off the clutch and oil pump to get to it.Drain the oil first. Maybe pan and clutch cover gaskets too. Details, details.....
