KZR750R1
  • kzr750r1
  • kzr750r1's Avatar Topic Author
Re: KZR750R1
01 Jun 2009 14:26
#295519
Pictures:
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
  • kzr750r1
Re: KZR750R1
01 Jun 2009 14:27
#295521
Cable retainer....
  • kzr750r1
Re: KZR750R1
01 Jun 2009 14:28
#295523
Bike now...
  • kzr750r1
Re: KZR750R1
01 Jun 2009 15:17
#295531
Talked to Derek at motolab...
Thanks for the yack D.
I will be placing a gage to judge throttle position.
Not many ZR motors out there with a kerker pipe and BS34 mm carbs.
Well see when I can get it down for a dyno run to start a new baseline for my basket of parts.
  • kzr750r1
Re: KZR750R1
27 Jun 2009 10:49 - 27 Jun 2009 10:52
#302468
Bumped the Needles up one notch. For some reason there was a spacer under the #1 needle only?
All are set at #3 notch, no space included in #1. Power picked up.
Took a long ride this morning and pulled th plugs for a look at color...
Seems a bit light to me. What do you guys think?
Last edit: 27 Jun 2009 10:52 by kzr750r1.
  • kzr750r1
Re: KZR750R1
27 Jun 2009 10:53 - 27 Jun 2009 10:55
#302469
Picture....
Last edit: 27 Jun 2009 10:55 by kzr750r1.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: KZR750R1
27 Jun 2009 12:10
#302487
Yeah, they do seem light...but fractionally so.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • kzr750r1
Re: KZR750R1
27 Jun 2009 12:24 - 27 Jun 2009 12:25
#302491
Hoping for a little adjustment on the primary and see how that helps low end.
Have to do the ol screw turn monkey business. Probably an 8th or 16th off, possibly less?
Adjusting the needle up one click sure gained top end and drivability through 5 and 6K.
Control is great with these on board. RS always was on the knife edge... Could reach the rev limiter in a hurry with those though. Haven't found the ceiling yet with these... Motor will be thankful for that.
Most driving seems to be around 3/8 throttle.
Passing going to 3/4 and it moves well. Can bog it down in 5th and pull out from bottom end much turmoil.
Kinda nice.
Last edit: 27 Jun 2009 12:25 by kzr750r1.
  • kzr750r1
Re: KZR750R1
29 Jul 2009 13:24
#310133
Moving through additional adjustments. Increased the Mains to 142.5. Was a big improvement in top end. Still seem to have a burble in transition from pilot to needle circuit.
Since I can't afford dyno time it's probably going to get some larger primary jets and see how it performs.
I screwed myself initially with more than one change and had to place the needle back to four. Three didn't cut it and four had the best midrange mix so far.
Interesting thing is the needle adjustment moves the burble up 1K RPM each clip change.
This is why I'm thinking of opening up the Pilot.
  • moto
  • moto's Avatar
Re: KZR750R1
29 Jul 2009 14:30
#310145
What throttle position does this happen at?
Are you referring to pilot jets?
This is when raising the needle?
Can you explain further?
Regards,
Derek
  • KawiConvert
  • KawiConvert's Avatar
Re: KZR750R1
29 Jul 2009 14:56
#310153
If it seems to hesitate and you want to see if its too lean, consider using the choke to see if it helps.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • kzr750r1
Re: KZR750R1
29 Jul 2009 16:11 - 29 Jul 2009 16:11
#310162
Pilots are what I'm referring to. Probably around 1/3 to half is where the hesitation (burble) is happening at 6K.
Unfortunately I'm not trusting this tack any longer. When things get busy it swings wild in the hi range after 7K when on the pipe... :)More motion on the tack than on the road.
As for testing with the enrichments opened may give some indication but I'm looking for that nice sweet spot. This would just dump more fuel than the next size Pilot Jet would be doing for me.
It may just be as close as I'm going to get with the financial compromise I have to make at the moment. Wait for payday and will be at Derek's doorstep.
I'll get some more runs in later this weekend and get a better handle on the throttle position.
Last edit: 29 Jul 2009 16:11 by kzr750r1.
