KZR750R1
06 Oct 2008 20:55 #240505 by kzr750r1
Replied by kzr750r1 on topic The KZR750R1 Return to life 08
Front turn signal mod. Fit's perfectly in the faring notch.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
06 Oct 2008 20:58 #240506 by kzr750r1
Motor repair painted. :)
06 Oct 2008 21:01 #240509 by kzr750r1
Reg./Rectifier perch.
06 Oct 2008 21:03 #240510 by kzr750r1
Leading to the case vent filter mount attached to the bottom of the rectifier bolts.
06 Oct 2008 21:04 #240511 by kzr750r1
Da Filter in location.
06 Oct 2008 21:05 #240512 by kzr750r1
Side cover mod. Note the half round ABS is welded in place to keep the tabs from flexing.
06 Oct 2008 21:07 - 06 Oct 2008 21:11 #240514 by kzr750r1
Exposed left side. Note the Zeypher faring grafted into the unit. Since I used the Zeypher wiring harness it made placement of the fuse box clean. Dyana 2000 barley fits in the old igniter slot.
Last edit: 06 Oct 2008 21:11 by kzr750r1.
06 Oct 2008 21:14 #240515 by kzr750r1
Battery box perch.
06 Oct 2008 21:16 #240516 by kzr750r1
Break accessories like Rear switch and Master cylinder oil reservoir.
06 Oct 2008 21:18 #240517 by kzr750r1
Rear m/c and Pipe hanger. Right rear set.
06 Oct 2008 21:20 - 06 Oct 2008 22:17 #240518 by kzr750r1
Pipe and motor detail left side. Ceramic coated black three peice Kerker 4 to 1 pipe. Nice stainless bung in place of an o2 pickup. Probably never use it but at least it's there.
Last edit: 06 Oct 2008 22:17 by kzr750r1.
06 Oct 2008 21:22 - 06 Oct 2008 21:24 #240519 by kzr750r1
And the item that was the butt of jokes for using duct tape to repair on the old forum. The new custom Corbin seat.
Last edit: 06 Oct 2008 21:24 by kzr750r1.
