Headlight upgrade 21 Aug 2016 10:06 #739380
  • jeffrwade
  • jeffrwade's Avatar Topic Author
  • Thank you received: 0
I have a 1982 KZ440 LTD Belt. I'm looking to upgrade the incandescent headlight to something with more visibility. I apologize in advance if this topic has already been hashed out in this forum. I've searched high and low for the answer to this question, but have not found a good solution, yet.
Please help!
Headlight upgrade 21 Aug 2016 11:23 #739383
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
I looked for a long time for a headlight for my 76 KZ400. I finally ended up getting an Emgo replacement headlight and chrome shell. Looks factory and the bulb is of the H4 type and replaceable.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Headlight upgrade 21 Aug 2016 12:33 #739392
  • jeffrwade
Thanks! Was the wiring straight forward?
Headlight upgrade 21 Aug 2016 12:41 #739393
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
No eBay APP ID and/or Cert ID defined in Kunena configurationI went HID. 1/3 the power draw and more light. Blue tint so drivers SEE me now.
Headlight upgrade 21 Aug 2016 12:51 #739395
  • ThatGPzGuy
jeffrwade wrote: Thanks! Was the wiring straight forward?
Just had to use some spacers and new bolts for the new shell. No wiring changes.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: by ThatGPzGuy.
Headlight upgrade 21 Aug 2016 16:19 #739412
  • jeffrwade
Thanks for the tip. I ordered one today.
Headlight upgrade 21 Aug 2016 17:49 #739422
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
jeffrwade wrote: Thanks for the tip. I ordered one today.
Does the smaller KZ's use a smaller diameter headlight?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Headlight upgrade 21 Aug 2016 18:14 #739425
  • SWest
  • SWest's Avatar
  • 10 22 2014
I took the H4 unit out of the 550 to put in my Z1.
Last edit: by SWest. Reason: correction
Headlight upgrade 22 Aug 2016 04:27 #739455
  • GPzMOD750
  • GPzMOD750's Avatar
  • Thank you received: 148
I put a set of relays in mine. It made a big difference with the stock headlight. The reserve lighting box didn't like it though so I had to delete that.
Headlight upgrade 22 Aug 2016 11:38 #739505
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
  • Thank you received: 87
I went with trucklite led bright bright bright. just plug and play. Uses less voltage than HID. Check it out.
Last edit: by 9er rider.
Headlight upgrade 22 Aug 2016 12:43 #739514
  • KZ650 Cafe
  • KZ650 Cafe's Avatar
Me too it works so good and looks awesome.
Sam
Headlight upgrade 23 Aug 2016 07:48 #739614
  • jeffrwade
I went with the Emgo light as recommended by @thatgpzguy. The opening on the bucket of my ltd 440 is 7". The incandescent light fixture and housing is quite proprietary. The light itself (diameter) is between a standard 5 3/4 and 7". Hopefully the Emgo lamp (halogen) and bucket will do the trick. Anything is better than incandescent!
