'80 KZ750E cafe build 24 May 2015 11:22 #673506
  • motomadlin32
  • motomadlin32's Avatar Topic Author
  • Thank you received: 0
Pics
'80 KZ750E cafe build 24 May 2015 12:30 #673515
  • Randombeat
  • Randombeat's Avatar
  • 0 to 100 real quick...
  • Thank you received: 23
Lookin really nice!
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
The following user(s) said Thank You: motomadlin32
'80 KZ750E cafe build 24 May 2015 13:25 #673524
  • motomadlin32
Hoping to get a reply soon on whether or not to use loctite.
'80 KZ750E cafe build 24 May 2015 16:11 #673539
  • Randombeat
I'll check my FSM for you and see what it says...
'80 KZ750E cafe build 24 May 2015 16:28 #673545
  • Randombeat
The factory service manual doesn't make mention of applying loctite or anything to the head bolts, just torqueing them in the correct sequence....
Maybe start a new thread asking the specific question will net you a faster reply...?
I've got one other resource I'm searching right now to try and find an answer for you.
'80 KZ750E cafe build 24 May 2015 16:33 #673547
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
Yes us red lock tight on the stud for the case side, and torque them to spec. do not use locktight on the head nuts.
'80 KZ750E cafe build 24 May 2015 18:05 #673559
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2627
Yup. You had to say not on the nuts too. I can hear the scream from here when he tries to get them off again. :whistle:
'80 KZ750E cafe build 25 May 2015 07:43 #673617
  • motomadlin32
Thank you guys for helping out. I ended up using blue loctite. Hopefully that will be sufficient. Everything is all torqued down, just gotta put the cams and everything back in. Hope it starts back up without issue haha
'80 KZ750E cafe build 25 May 2015 13:44 #673671
  • motomadlin32
Lost one of the halves for the exhaust collar, frustrated grrrr.
What engine oil do you guys recommend?
Last edit: by motomadlin32.
'80 KZ750E cafe build 27 Sep 2015 11:59 #692163
  • motomadlin32
Haven't done an update in awhile, but it's come a long ways. Pics and video.
I'll probly post in a different area. I think my build thread kinda died out.
