'77 KZ 900/1000 street/drag project
- sc/ant864
18 Aug 2012 15:29 - 19 Aug 2012 15:28
Here is my project, I've owned this bike for 6 years and never even taken it for a ride....I know it's depressing. The engine has bad idlers so I'll have to replace those and the cam chain before even thinking about taking it for a spin. When the bike was running we could hear the chain slapping the cam cover, could be a bad auto adjuster but I'm not taking any chances with my valves. First I plan to swap the front end for an 88'FZR 1000 I have from a "parts" bike and redo my cobjob rearset mounting, I used the rearsets from the FZR, but the way I have them mounted now is just too high,silly and unsafe. I pulled the FZR front end apart last night so it will be ready to rebuild. Here's a few pics showing my horrible attempt at rearsets,FZR forks/triples and front wheel,and the 2 chipped fins on my head that I will need to repair.
Attachment IMG_20120818_123655.jpg not found
Attachment IMG_20120818_123743.jpg not found
Attachment IMG_20120818_123835.jpg not found
Attachment IMG_20120818_123850.jpg not found
Attachment IMG_20120818_124151.jpg not found
Attachment IMG_20120818_124240.jpg not found
Attachment digicam034.JPG not found
kzrider.com/forum/11-projects/543276-77-...543286]'77KZ900-1000
streetstrip project
'77KZ900/1000
'89BMW E30 325i sedan
'88Mustang GT
'77Datsun PL620 KingCab
George Carlin- "I often think how different the world would be if Hitler had not been turned down when he applied to art school."
'77KZ900/1000
'88Mustang GT
Last edit: 19 Aug 2012 15:28 by sc/ant864.
- 4TheKZ1000
Re: 77' KZ 900/1000 street/drag project
18 Aug 2012 15:47 - 18 Aug 2012 15:50
I would take a hard look at that motor FIRST! I would crack cases and do a good once over. You will be shocked of all the chit in the oil pan.
Last edit: 18 Aug 2012 15:50 by 4TheKZ1000.
- sc/ant864
18 Aug 2012 16:56
Well I have changed the oil a few years back and it was actually a beautiful amber color which I was quite happy to see and the filter was also in great shape but alas I'm sure this will be in the works when I change the idlers. Isn't it possible to change them with the engine still in the frame?
streetstrip project
'77KZ900/1000
'88Mustang GT
'77KZ900/1000
'88Mustang GT
- wireman
18 Aug 2012 20:12
Yes you can do a top end rebuild with motor still in frame,but if youre going to all the trouble its not that much more work to split the cases and check the bottem end out and throw a cam chain in there.
- sc/ant864
18 Aug 2012 20:27
Ok thanks for the replies 4thekz1000 and wireman, I have to agree this most likely is the route I need to take. Would/should I get a complete gasket set for this and any suggestions?
streetstrip project
'77KZ900/1000
'88Mustang GT
'77KZ900/1000
'88Mustang GT
- wireman
18 Aug 2012 20:50
Yes id get a complete gasket set,pull everything apart and clean everything really good.
If anything looks questionable in the bottem end replace it while youre there,id suggest having the crank checked/welded as long as youre in there then you shouldnt need to get back into the bottem end for a long time
- sc/ant864
23 Aug 2012 14:54
Ok I found 2 different makers of gasket kits Vesrah and Athena and a NOS factory kit for $15 bucks more than the others, any difference or better quality on one versus the others?
streetstrip project
'77KZ900/1000
'88Mustang GT
'77KZ900/1000
'88Mustang GT
- wireman
23 Aug 2012 15:05 - 23 Aug 2012 15:05
Ive never had a problem with the vesrah or cometic gasket sets,although i copper coat both sides of the paper gaskets before installing no matter what brand
Attachment PERMATEX20SPRAY20COPPER20COAT_2012-08-23.jpg not found
Last edit: 23 Aug 2012 15:05 by wireman.
The following user(s) said Thank You: bluezbike
- sc/ant864
23 Aug 2012 15:19
Good to know wireman, My buddy uses Honda-bond on all his gaskets for his KZ1000 and CBR900RR but I'll try that Permatex, looks like good stuff.
streetstrip project
'77KZ900/1000
'88Mustang GT
'77KZ900/1000
'88Mustang GT
- wireman
23 Aug 2012 21:48
My backhoe mechanic turned me on to it years ago,its da bomb!
- sc/ant864
Re: '77 KZ 900/1000 street/drag project
24 Aug 2012 01:22 - 24 Aug 2012 01:25Attachment IMG_20120823_235556.jpg not found
Engine is out, wow that thing is heavy next time I'll get help. My arms feel like I went to the gym for a full day.
streetstrip project
'77KZ900/1000
'88Mustang GT
'77KZ900/1000
'88Mustang GT
Last edit: 24 Aug 2012 01:25 by sc/ant864.
24 Aug 2012 10:07
those engines are heavy,awkward,finger biting,sonsab!tches :pinch: .
some rubber/vinyl tubing split lengthwise is a good frame protector.
available from most home improvement stores,
