76 KZ900a semi restoration
- Tomolu5
18 Jun 2012 18:51 - 07 May 2014 16:22
Well, I had a lot of this project kind of done when I joined here, and my work has had me running around like a maniac for quite a while now(really helped with funding this venture). I figure this is as good a time as any to start my project thread. This bike was bought new by my father in 76, he rode it like it was stolen for the first chapter of its life. The oil and such was changed regularly, but im certain the engine has seen more revolutions than the odometer would indicate. It sat from about the time I was 6 or 7 until I turned 16. It took some doing, but I convinced him that I wasn't a maniac like him(sorry dad). The bike got put on the road then, with the necessary repairs and improvements(modern regulator/rectifier, chain sprockets, brake pads, cables...I might have done more, but the resources just weren't as easy to find then, All of my friends were downloading songs from napster every night, And I was starring at Pics of Mellisa on oldkawman.com :laugh: I rode her for a few years(racked up some miles too!) and eventually she got sidelined in favor of my less finicky crotch rockets. Fast forward 10 years or so till now, and an older wiser married version of myself decided that maybe, just maybe the wife might like riding a bike with a seat on the back. The is what I found after I resurected her from her tomb, and hit her with a pressure washer real quick
anyways, time for a dinner break, more to come
Attachment IMAG0054resize.JPG not found
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
Last edit: 07 May 2014 16:22 by Tomolu5.
The following user(s) said Thank You: Sactown900
- Tomolu5
Re: 76 KZ900a semi restoration
18 Jun 2012 19:53
I started by making a "short" list of things that needed attention, bear with me, I am going by memory here.
-either rechrome, or find replacement pipes. It has LTD pipes on it, and I like them so I wanted to stay with them or at least similar
-need left side cove(lost)-also need to do the "keeper" mod on other one
-new case savers
-it always would oil foul #1 on a cold start-up(what a pain) so new valve seals were in order.
-While it was down that far, might as well give it some rings
-Brakes, something needs to happen there, they always used to squeal, I cant have that. also I am not sure if Im just spoiled by gixxer brakes, or if the single front disc always sucked this bad, I would be better off with a cinder block tied to a rope.
-Once I saw the cost of the dyna s system, and new coils(if only to change the wires), I couldnt pass that up.
I wasn't looking to go crazy and modify the crap out of this bike, just want a nice dependable rider, one that can leave a harley, or even a poorly ridden 600 behind :evil:
here are some photos from day 1
damp basements suck!
-new case savers
Attachment IMAG0055.jpg not found
Attachment IMAG0056.jpg not found
Attachment Torndown.JPG not found
Mine:
- Tomolu5
18 Jun 2012 19:57 - 18 Jun 2012 19:58
forgot the front fender was pretty pitted, came across a NOS one for a couple hundred bucks, looks great
you can see it in this photo
Attachment IMAG0147.jpg not found
Mine:
Last edit: 18 Jun 2012 19:58 by Tomolu5. Reason: wrong pic
- Tomolu5
18 Jun 2012 20:08
some pictures from the next week or so as I tore it down
bringing engine home, along with dog and gixxer tire
lots of crud in there
I have never torn into a head, but whats the worst that could happen?
Attachment IMAG0061.jpg not found
Attachment IMAG0063.jpg not found
Attachment IMAG0065.jpg not found
Attachment IMAG0075.jpg not found
Mine:
- Tomolu5
18 Jun 2012 20:37
So this is where I got lazy with the camera, But I tore the head down,(bagged and tagged everything), replaced the seals, and lapped the valves that didn't look so sexy. Next reassembled the engine(incorrect timing marks and all), Paid through the nose for some various sized valve shims, and then reassembled the bike. Im sure more than a few of you know the let down in my heart when she didn't fire right up, or try to, or cough, belch, not even fart. @#$#@, I can feel air puffing out of #1 carburetor TIMING... So I read, and read, and searched, then eventually between google spitting me here, and the 1 friggin photo of this process in my clymers manual, I was able to use my decoder ring and discover the process. I ignored the warning to just tear down now, because I had turned the engine over by hand several times with no resistance, retimed it and it fired right up! Took a short video of it running to put on youtube to show my riding buddy, and took it for a ride
My bliss was soon soured as the very next time I started it, it puke oil smoke for the first 5 minutes (alot). after a couple of retries, because perhaps it was a fluke that all the oil got there :blush:, I tore It apart. The was no less than A tablespoon of oil sitting on top of the pistons, and it sat there for a while before draining back down :dry: . So in my mind, I obviously screwed up in the head, I figured the oil was dumping into the cylinders from above, since it took so long to go down. I started looking for somebody to go through the head, fix my stuff, replace any bent valves, ETC. I was led to Larry C from this site, and took the head to him, and regailed him with this gripping saga. He suspected that I overlapped my oil control rings from square 1, which I did, looked like thats how they went to me :blush: . but at any rate, my ebay seals were crappy, and most guides were crap, and I still thought it to be a good Idea to have him go through it(I was right, for once) and he was quite generous to share some of his wealth of knowledge with me. That catches us up to last weekend.
Mine:
- Tomolu5
18 Jun 2012 20:43
While the head was out, I made a soda blaster and hit the carbs, then tore them down and set them up on a bench, I learned of the clear tube method here, and I was Way off before!
before
after
bench tunning
Attachment carbsbefore.JPG not found
before
Attachment carbsafter.JPG not found
after
Attachment cleartubemethod.JPG not found
bench tunning
Mine:
- Tomolu5
18 Jun 2012 20:58
Then I got the head back, man this thing looks awesome. It has taken every single ounce of my personal strength(and good sense) to keep from popping a valve out just to look.
Im so friggin excited to hear her run with this thing, Plus what Im thinking will finally be a proper tune job. Im like a diamond in an ice storm :laugh:
among the other things I leaarned, I was only getting half spark or so due to my suppresion wires and resistor caps, so I gotta redo that, but this is where I left here before having to do the fathers day thing
Turns out I lost some of the valve cover bolts, and screws for the intake boots, so im going to launch that search party now, just wanted to get this thread up!
cheers!
Attachment headbottom.JPG not found
Attachment Intakeport.JPG not found
Attachment whereIlefther.JPG not found
cheers!
Mine:
- Tomolu5
19 Jun 2012 23:05
Found the bolts, and intake boots, It was just a matter of figuring out where I put them to "keep them from getting lost". I went down tonight, Tightened down the valve cover, installed the carbs, new tach cable and ignition wires. I could have got the pipes on and fired her up(hopefully), But I opted to heed the advice I received here and drop the oil pan to have a look. I sure am glad I did, as I found an oil pump pick up screen at least 70% covered in crap. This might not have been a problem, but I dont want 70% of my arteries clogged up with crap(despite my diet :woohoo: took some pics, I'll try to get them up tomorrow
for my fellow hockey fans, NHL awards tomorrow
Mine:
- Flyndrive
20 Jun 2012 00:24
Wow that thing is looking great! What did you use to polish and clean you engine?
1980 KZ 550A1
1985 GPZ 900R
1985 GPZ 900R
- aafadca
20 Jun 2012 00:36
Just curious. How did you figure out your suppresion wires were cutting your spark,etc?
1976 kz900
- KZJOE900
- Admin
20 Jun 2012 01:05
Nice quality work Tomolu5. Bike is starting to look great!
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Tomolu5
20 Jun 2012 06:24
Flyndrive, on the rougher castings such as cylinders and cases I used a dremel and little wire brushes, mostly soft steel, some brass. On the smoother castings, like the covers I used a polishing setup to bring them out. You could get them same effect by wet sanding down to 1200, then using mothers aluminum polish, or flitZ.
Mine:
