New project.1428 turbo or supercharged, Who knows? 13 Dec 2012 06:25 #562771
  • zed1015
  • zed1015's Avatar Topic Author
  • Thank you received: 1476
bluezbike wrote: Is it possible to anodize the centers black after getting them back to bare aluminium? Would you have to strip the disc to separate components to do this? I think back to bare alu for a start, those forks you did are beautiful Zed.
I agree paint won't last, don't know if powder coating would work.
Yes! could re-anodize them but would have to strip out the center which means new buttons and more importantly more £££ etc :laugh:
Think the bare alu is the way to go for now to keep things rolling and see what happens later,
The intricate shape of the centers will be hard to keep clean which is my main concern but it is no big job to pull the wheel later and change them.
New project.1428 turbo or supercharged, Who knows? 17 Dec 2012 15:57 #563387
  • zed1015
Done the deed and stripped the discs.
Also scored an XJR1300 front muddy on ebay which arrived today and will need some trimming and brackets make it fit
New tyres on also and one step closer to removing the wooden stand
New project.1428 turbo or supercharged, Who knows? 17 Dec 2012 18:27 #563411
  • bluezbike
  • bluezbike's Avatar
  • Thank you received: 104
Looking very sharp Zed. Interesting use for a clutch cover. Is your plan to leave the oil cooler as it is or maybe add a small fairing? Might work well with the new trimmed ignition cover. Is the swing-arm pivot point on this frame in exactly the same place as it would be in a KZ frame??
79 KZ 1000 LTD
New project.1428 turbo or supercharged, Who knows? 17 Dec 2012 19:25 #563421
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
  • Thank you received: 109
that xjr1200 fender is the closest thing to a stock KZ, in a 17" that ive seen.
Very nice. B)
i used a zx6 and massaged it to make it look stockish.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: by mark1122.
New project.1428 turbo or supercharged, Who knows? 17 Dec 2012 19:35 #563423
  • zed1015
bluezbike wrote: Looking very sharp Zed. Interesting use for a clutch cover.
Had to use something to stop the wheel turning so the muddy didn't fall off :lol:
bluezbike wrote: Is your plan to leave the oil cooler as it is or maybe add a small fairing?
Going for the naked racer look (The bike not me :blush: :laugh:)so no fairing.
But maybe a bellypan?
bluezbike wrote: Is the swing-arm pivot point on this frame in exactly the same place as it would be in a KZ frame??
Pivot is closer to the engine by 5mm (hence my previous swingarm pivot mod) but is still in the correct plane.
New project.1428 turbo or supercharged, Who knows? 17 Dec 2012 19:42 #563424
  • zed1015
mark1122 wrote: that xjr1200 fender is the closest thing to a stock KZ, in a 17" that ive seen.
Very nice. B)
Thanks.
I also used an XJR one on the Drouin so going for a similar look but maybe rotate it forward a bit more.
New project.1428 turbo or supercharged, Who knows? 08 Jan 2013 13:05 #566358
  • zed1015
Bit more progress.
Painted the rear caliper mount and got it all finished and fitted .
This allowed me to fit the footrests, hoses and bleed the brake.
Bulky reservoir will probably be replaced by a short length of clear hose.
Other side got new sprocket studs and nuts and is ready for chain fitment.
Front end got the bars fitted and controls . R1 starter/kill switch now serves as Horn and kill.
The bars were stripped of the gunmetal and repainted black.
All this means i can junk the wooden stand and it's now capable of standing on it's own two wheels .
Couple of shots with the tank slotted on
New project.1428 turbo or supercharged, Who knows? 08 Jan 2013 13:43 #566360
  • Thank you received: 2829
For that brake reservoir, have you considered using a Ducati clutch reservoir? Some of them are tiny. Here's one; it's possible there may be others even smaller:
Attachment 00000_2013-01-08.jpg not found
New project.1428 turbo or supercharged, Who knows? 08 Jan 2013 16:29 #566373
  • zed1015
Yes! That was my first idea as i have got a small Brembo clutch reservoir but it still looks wrong.
A piece of clear tube with a stopper will be neater and do the job as long as i leave an air gap above the fluid for expansion.
New project.1428 turbo or supercharged, Who knows? 08 Jan 2013 18:36 #566390
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
  • Thank you received: 59
Coming along nicely. Bit late to do a dry clutch conversion I suppose :)
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
New project.1428 turbo or supercharged, Who knows? 08 Jan 2013 19:05 #566396
  • zed1015
Lorcan wrote: Coming along nicely. Bit late to do a dry clutch conversion I suppose :)
Only if i forget to put the oil in :blink:
New project.1428 turbo or supercharged, Who knows? 08 Jan 2013 19:52 #566406
  • zed1015
THOUGHTS ?
Should i junk my alloy seat for a KR750 one like in the piccy ?
