New project.1428 turbo or supercharged, Who knows? 07 Mar 2013 18:18 #575836
  • wireman
  • wireman's Avatar
  • Thank you received: 299
Attachment notworthygroup_2013-03-07.gif not found
B) B) B) B) B)
New project.1428 turbo or supercharged, Who knows? 07 Mar 2013 18:52 #575849
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
once again you have justified my mantra,
"it sucked for that.
but,
it made a badassed one of these." :P
great job sir,
i would expect no less from a skinflint such as you :silly: .
New project.1428 turbo or supercharged, Who knows? 07 Mar 2013 20:22 #575861
  • wireman
  • wireman's Avatar
I love the clutch actuater,but does it drive anybody else nuts that the of the pmfr plate sits on a totally different plane than the rest of the motor? :blink:
New project.1428 turbo or supercharged, Who knows? 07 Mar 2013 20:56 #575873
  • LarryC
  • LarryC's Avatar
  • Thank you received: 309
zed1015 wrote: In a rare fit of extravagance i bought a PMFR clutch release mount (it was cheap) as the offset sprocket and chain fouled the original sprocket cover and i didn't want to cut it about as it's a 72 jobbie without the 1n2345 cast in to it.
Trouble was the zx10r clutch cable wasn't long enough to go the normal route under the alt cover but would easily reach under the carbs to here.
A chance to redeem myself for my frivolous spending saw this collection of alloy offcuts and bits from the scrap bin heading for a new life.
Along with the ally, an old exhaust valve , a guide, 10mm stainless bolt, ball bearing and a bit of brass bar were attacked with the lathe for a couple of days
To produce these
The short lump of ally combined with the old valve guide forms the main body.
The bar stock and brass offcut create the arm with pivot bush.
The turned down valve serves as a hardened pusher and the modified bolt with ball bearing pressed in the end provides the adjuster.
A bit of offset turning creates the arm mounting and the 7mm valve guide bore just happens to match the size of the clutch push rod.
Modded valve slides in here
And adjustment screw here
Then the arm slots on to the mount.
Ball bearing runs on the hardened valve pad for a smooth action.
The valve stem was trimmed down to meet the clutch pushrod midway in the guide with a ball bearing between them
And viola. One fulcrum arm clutch actuator ;)
Just got to finish off with the outer cable mount and job done.
Zed....ya done it again....impressed me with your common sense approach to a problem without spending big bucks. That is just plain slick!!
Larry C.
New project.1428 turbo or supercharged, Who knows? 09 Mar 2013 02:59 #576085
  • Hollywoodmx
  • Hollywoodmx's Avatar
  • Thank you received: 16
531blackbanshee wrote: once again you have justified my mantra,
but,
great job sir,
Yes his skills are amazing and inspiring. When he used that road sign is what really blew me away. When I was looking to solve my swing arm issue his use of the stop sign made me think of using the R1 steering stem (since I wasnt using it) as the metal for the pivot bold insert for my R1 swing arm and it worked like a charm.
He should rename himself to macguyver.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
New project.1428 turbo or supercharged, Who knows? 09 Mar 2013 06:50 #576097
  • zed1015
  • zed1015's Avatar Topic Author
  • Away
  • Thank you received: 1474
Necessity is the mother of invention and all that.
Anyhow here's a pic of the finished item with cable mount.
The following user(s) said Thank You: Bad Kaw
New project.1428 turbo or supercharged, Who knows? 09 Mar 2013 09:01 #576099
  • turboking
  • turboking's Avatar
  • Thank you received: 106
nice work..... :woohoo:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
New project.1428 turbo or supercharged, Who knows? 09 Mar 2013 14:03 #576148
  • wireman
  • wireman's Avatar
B) B) B) B) B)
New project.1428 turbo or supercharged, Who knows? 09 Mar 2013 14:09 #576151
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Thank you received: 1983
wireman wrote: B) B) B) B) B)
Totally Awesome Work !!!!!
B) B) B)
New project.1428 turbo or supercharged, Who knows? 12 Mar 2013 22:42 #576752
  • 750steve
  • 750steve's Avatar
I know you from somewhere Rob! lol
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
New project.1428 turbo or supercharged, Who knows? 22 Mar 2013 15:15 #578170
  • zed1015
  • Away
Made some progress on modding the carbs today.
Started by making this jig .
That bolts to the carb
Which allows it to be securely mounted central in the lathe chuck
After quite a few carefull light cuts and a high speed finish
I had one 26mm carb bored out to 29.5mm
Repeat three more times and i have a full set. :D
Next job is to make a cutter to re-seat the slides in the bottom of the slide bore
New project.1428 turbo or supercharged, Who knows? 22 Mar 2013 15:52 #578178
  • wireman
  • wireman's Avatar
Are you boring them to 29 or 31s,what motor are you using them on? :)
