New project.1428 turbo or supercharged, Who knows? 07 Dec 2012 19:26 #561924
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
  • Thank you received: 36
zed1015 wrote:
mtbspeedfreak wrote:
zed1015 wrote:
I'm probably not seeing this, but what happens if you push the bike backwards and the pads scrape the rotor - wouldn't the caliper be swung around?
No! There's a bobbin that sits against the under side of the arm also (see the second to last pic in the caliper mount mod section on the previous page)
The caliper mount is locked in place and can't move in either direction.
I have since moved the permanently fixed bobbin to the loaded side(top)and moved the eccentric adjuster to the bottom position as it need less rotation to take up any slack and i feel is a stronger set-up.
Ahhh gotcha. I noticed that bobbin, but I wasn't sure it was connected. I was pretty sure you wouldn't have missed that mundane detail, but thought I'd ask anyway. B)
2000 ZRX 1100
1976 KZ 900- Daily Driver
New project.1428 turbo or supercharged, Who knows? 09 Dec 2012 19:03 #562218
  • zed1015
  • zed1015's Avatar Topic Author
  • Away
  • Thank you received: 1481
Decided to get on with the front end whilst i wait for a back sprocket to turn up.
Fitted new taper rollers, painted the top yoke and slotted the forks in.
Quickly came to the conclusion that the gold anodised forks look shite so had to do something about it.
Had bought some Sodium hydroxide crystals from Gateros plating to strip the anno from the R1 calipers gold stars so decided to do the same to the forks.
Only fly in the ointment was that i had rebuilt them with new seals etc after i had extended them.
Not wanting to pull them apart and risk damaging the seals just yet i decided i had nowt to lose by having a go at stripping them whilst they are in one piece.
As they say on the telly .. DO NOT TRY THIS AT HOME :lol:
After a bit of experimentation with the concentration of the solution and suitably equipped with goggles and rubber gloves i carefully set about sponging the sodium on the the leg.
After only ten minutes and a wipe with clean water i had this
Very suprised how clean and easy it came off and with no smutting .
Only 90 mins work from start to finish and i had this.
Spot the difference :D
Quickly perfected the technique and after another 20 mins job done.
Don't mind the gold on the damping adjusters so i'll leave it on.
Last edit: by zed1015.
New project.1428 turbo or supercharged, Who knows? 09 Dec 2012 20:21 #562228
  • wireman
  • wireman's Avatar
  • Thank you received: 299
Much better! B)
New project.1428 turbo or supercharged, Who knows? 09 Dec 2012 22:37 #562248
  • jarrad
  • jarrad's Avatar
  • Thank you received: 4
mate that looks great!
im doing the same to the ZX636 forks on my Zed! cant wait to get it done now!
New project.1428 turbo or supercharged, Who knows? 10 Dec 2012 14:07 #562333
  • zed1015
  • Away
Same treatment for the calipers.
Pretty sure the grey finish on the calipers is anno too so not wanting to risk taking any of that off i knocked up a five sided tool to unscrew the gold stars
Nothing too fancy just attacked a bit of scrap ally with the angle grinder till it fitted something like
They came out much easier than expected and are only sealed with an 'o' ring and no thread lock.
One done and three more to go.
New project.1428 turbo or supercharged, Who knows? 10 Dec 2012 14:28 #562335
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
  • Thank you received: 109
Great job. B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
New project.1428 turbo or supercharged, Who knows? 10 Dec 2012 15:51 #562348
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
  • Visitor
BAD-ASS....that looks friggen awesome...now I want one...gold is out :blink:
Some people get it some dont.....Your the man!!!!!!!!!!
Last edit: by 4TheKZ1000.
New project.1428 turbo or supercharged, Who knows? 10 Dec 2012 16:55 #562364
  • Thank you received: 2829
That looks a million times better than the gold! I assume the person who decided new forks had to be anodized gold also has a prominent gold tooth. :laugh: :laugh:
New project.1428 turbo or supercharged, Who knows? 12 Dec 2012 19:06 #562685
  • zed1015
  • Away
Very close to getting back on it's wheels.
Got a new set of tyres waiting to go on and received this dural blank rear sprocket from Dennis Trollop Racing this morning.
After some very carefull setting up in the lathes four jaw it was bored out to fit the zx10 sprocket carrier and just needs some stainless studs making to bolt it up.
Only thing slowing the progress to this milestone is the offending gold discs.
Really want black centers but not keen on painting them as they soon get tatty around the buttons and i don't think leaving them gold is an option, should i paint them black or just strip the anno back to bare ally for now ???
New project.1428 turbo or supercharged, Who knows? 12 Dec 2012 23:14 #562720
  • les holt
  • les holt's Avatar
  • Vendor
  • Thank you received: 288
Question on the sprocket, is it aluminum or steel? is it hardened? I can see some neat ideas coming from a blank.
Les
New project.1428 turbo or supercharged, Who knows? 13 Dec 2012 03:00 #562758
  • bluezbike
  • bluezbike's Avatar
  • Thank you received: 104
Is it possible to anodize the centers black after getting them back to bare aluminium? Would you have to strip the disc to separate components to do this? I think back to bare alu for a start, those forks you did are beautiful Zed.
I agree paint won't last, don't know if powder coating would work.
79 KZ 1000 LTD
Last edit: by bluezbike. Reason: add more ideas
New project.1428 turbo or supercharged, Who knows? 13 Dec 2012 06:17 #562770
  • zed1015
  • Away
les holt wrote: Question on the sprocket, is it aluminum or steel? is it hardened? I can see some neat ideas coming from a blank.
Les
Hi, yes! it is hardened Aluminium (look up Duraluminium on google etc).
Lots of possibilities for holes etc but i quite like the simple no nonsense look as it is at the moment so will probably leave this one alone.
