New project.1428 turbo or supercharged, Who knows? 18 Nov 2012 15:10 #558973
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
  • Thank you received: 443
Zed, hope you don't mind if I ask a few dumb questions. Since I have never seen this type of set up before. So from what it looks like, you are installing an electronic ignition in place of where the stator resides, correct? I'm anxious to know, were and what will take place of the stator?
Love your work and ingenuity.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: by KZJOE900.
New project.1428 turbo or supercharged, Who knows? 18 Nov 2012 15:57 #558982
  • zed1015
  • zed1015's Avatar Topic Author
  • Thank you received: 1474
KZJOE900 wrote: Zed, hope you don't mind if I ask a few dumb questions. Since I have never seen this type of set up before. So from what it looks like, you are installing an electronic ignition in place of where the stator resides, correct? I'm anxious to know, were and what will take place of the stator?
Hi,yes! correct.
It's a self generating race ignition which needs no battery.
Just like a dirt bike you only need to kick it over and away you go.
It has an electronic advance curve built in and a kill switch on the bars to switch off.
I won't be fitting a charging system but will be running a total loss battery in the seat tail to run the brake light and horn which is the minimum requirement for daytime running over here.
The following user(s) said Thank You: Bad Kaw, KZJOE900
Last edit: by zed1015.
New project.1428 turbo or supercharged, Who knows? 19 Nov 2012 10:45 #559103
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
water isn't going to effect it?
mudhole splash,dead bike :pinch: ? :huh:
i like the kidney shaped holes myself ,
New project.1428 turbo or supercharged, Who knows? 19 Nov 2012 16:00 #559139
  • zed1015
531blackbanshee wrote: water isn't going to effect it?
Water wouldn't normally effect it,i have seen plenty of race bikes running these in the wet with no cover fitted at all.
But then you really think i will be taking this bike out in the wet ? :laugh: :laugh: :laugh:
New project.1428 turbo or supercharged, Who knows? 19 Nov 2012 16:42 #559146
  • Thank you received: 2829
So we can safely assume you will not be following this guy down the road? :laugh: :laugh: :laugh:
Attachment 00000_2012-11-19.jpg not found
New project.1428 turbo or supercharged, Who knows? 19 Nov 2012 17:03 #559150
  • 531blackbanshee
  • Vendor
you do live in england :P !!!!!!!
Last edit: by 531blackbanshee.
New project.1428 turbo or supercharged, Who knows? 19 Nov 2012 19:21 #559184
  • zed1015
After making the rounded ignition stone guard i've decided that the blanking plate for the original points location looked a bit pants and needed something else
So i removed the turned center which was just a press fit and welded it in to a later points cover which had enough meat on to allow a matching profile to be shaped on it
Think that's a big improvement and it actually matches the stone guard now.
New project.1428 turbo or supercharged, Who knows? 19 Nov 2012 21:55 #559209
  • 531blackbanshee
  • Vendor
crafty lil bugger now ain'tcha :laugh: !
New project.1428 turbo or supercharged, Who knows? 20 Nov 2012 00:26 #559229
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
  • Thank you received: 35
zed could we have some backround on you. im curious as to what you do for a living and how much time you have in custom bike building. dont mean to be nosey but your a master fabricator and the work you do is really outside the box. its inspiring and i just wonder what type of person puts this kind of work out. sorry if it seem personal or creepy lol
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
New project.1428 turbo or supercharged, Who knows? 22 Nov 2012 11:25 #559610
  • zed1015
Top end done and re-designed blanking plate painted.
Stone guard painted and on.
Decided to leave it plain for now
New project.1428 turbo or supercharged, Who knows? 22 Nov 2012 12:33 #559619
  • LarryC
  • LarryC's Avatar
  • Thank you received: 309
That's coming along quite nicely :)
Larry C.
New project.1428 turbo or supercharged, Who knows? 23 Nov 2012 06:41 #559729
  • Spike j
  • Spike j's Avatar
  • Thank you received: 0
Fekin awesome build dude :)
1979 KZ1000 ST
