Search Results (Searched for: gs swing arm)
Nessism wrote: WOW! Those S1 swingarms are impossibly cool! Wish I could ride hard enough to out handle my stock swingarm because if I could I'd have me one of those things!
Just let the swingarm bearings dry out and fail, then just pretend its your sublime skills that are making the bike buck and weave, buy new swingarm....Problem solved... :woohoo:
I'd love one too, my wallet says otherwise....
Replied by Nessism on topic history on cal fab swingarm
12 Nov 2016 11:19
Replied by Zephyrrider on topic Zephyr 750 torque settings
09 Nov 2016 11:20
Hey Steve, I am doin fine mate -
How are you ?
BK - it is 450 mm from centre of swing arm pivot to centre of shock mount.
How are you ?
Replied by Kidkawie on topic Lowering
08 Nov 2016 04:51
OutlawShank wrote: Thanks, how do you suggest lowering the rear?
Shorter shocks is the easiest route. You should remove the shock springs (Google shock spring removal zip tie), install the shocks and actuate the swingarm to look for any contact with the fender/chain, etc. If the tire hits the fender you need to install a longer shock bumper or shorten the shaft.
Replied by Zedone on topic KZ900 A4 FRUSTRATED- Can't get valve timing right
02 Nov 2016 13:18
Hi Kats,
Can you post a few pics of your bike? A few areas you want to check are, the swingarm pivot bushing, wheel bearings, steering head bearings, brake caliper pistons, master cylinders and for sure flush out that fork oil. One thing I always do before tearing down any engine is check all my valve clearances and write them down for reference, keep a log book specific to that bike. When reinstalling cams be sure not to get mixed up with your ignition rotor marks as their is a 1/4 TDC and another mark to the left for your ignition. I always turn the engine over by hand using the large nut on the end of the crankshaft @ 6 times or so with the plugs out to make sure valve assembly does not bind or get familiar with the pistons... just to make sure.
Doug
Doug
Replied by 750 R1 on topic Balancing wheels
29 Oct 2016 18:50
To the OP, I would be checking steering head bearings, wheel bearings, both front and back, and swingarm bearings, all of these things can lead to a high speed weave or wobble, I doubt it is a tire out of balance thats causing problems over 90MPH, also make sure your tires are seated properly and as mentioned, make sure the valve mark on the tire is lined up. I've seen plenty of poorly seated tires , although they usually lead to a up and down type of wobble, if that makes sense...
That video played like an anti motorcycle propaganda piece.Kidkawie wrote:I_Tig_in_piece wrote:650ed wrote: If you had a 72 mph speed wobble something is still wrong with the bike and the damper is only masking the problem. I guarantee you that the bike didn't have a speed wobble when it left the showroom floor. #1 suspect would be tires, but bad shocks; worn swing arm bushings; bad steering stem bearings; wheel bearings; untrue rim; etc. are also possibilities. I highly recommend you identify and correct the problem. My KZ650 had a wobble at 90 mph and after replacing all bearings, bushings, shocks, etc. it turned out to be a bad tire (Michelin Macadam) even though both tires looked perfect. After replacing the tires the bike is now as solid as a rock up to top speed (120 mph). Ed
Before the first wobble, all the items you mentioned had maybe 400 miles on them from new. AB bearings everywhere except the swinger which is a NOS set. I trued the wheels myself then had them OK'd by a few buddies at Trophys. Followed the directions on kz400.com to the T to rebuild and fill the forks. I pressed the new top and bottom AB races on but I didn't re-torque the stem after putting some miles on them.
My Z1B with stock forks and reproduction OEM shocks would weave above 80mph. Not headshake, but a whole bike weave. I installed a set of ZRX shocks which were plusher and a touch longer and the weave has disappeared. With these old bikes you have to pay attention to setup. You can't just slap suspension on (no matter what it is) and call it done. Some good info in this video.
I've never had any of my medium and big road bikes do any of that BS!
And I ride from 55mph to 85mph for quite a few miles nearly every time I go out .
Today included.
Replied by Bozo on topic GPZ1100 Frankinbike is close to finished
17 Oct 2016 14:11
aquaholic wrote: Hello there, I am doing a rebuild on a 1981 KZ1000 J2 and was curious about the wide tires from the Honda. Did you have to do any modifications to the swing arm to get the clearance for the wider tire ? Drop me a line when you have a minute please. And i have to say that is one very sharp Frankin' Bike. Excellent job. Be well and thanks in advance.
Hi, thanks glad to help with your inquiry, The honda wheels were from a 2006 CBR1000F the rear is a 170 x 17 and it was a challenge. The only reason I Persisted was because I got both wheels for a good price. If I had to do this again I'd look at other wheels. The axle had to be specially shortened and rethreaded. The brake disc was from a CB750 to suite the GPZ900R caliper.
The rear sprocket hub stuck out a long way and to make it central took a bit of machining, lucky for me a had a friend with a workshop.
The swingarm was already on the frame when I bought it, I believe it was from a later GPZ900 or 750R, again I got this for a good price so I can't really comment much about whether any or much modification was required.
The front wheel wasn't much of a problem but did require new/ old spacers made to fit. It does not have a speedo drive but I have a GPS speed which does not require a drive.
I will be happy to help if you still want to go ahead but if I was to do this again I'd find another set of wheels maybe GSXR750/1000.
Let me know (PM me) if you have other questions. I'm not at home presently so don't expect a quick response.
Replied by chonus on topic 1980 kz750 h1 hurricane matthew damage
16 Oct 2016 16:24
So i know the swingarm bearings arent sealed but arent the wheel bearings sealed? And there was zero water in the oil.
Displaying 861 - 870 out of 7224 results.
