1980 kz750 h1 hurricane matthew damage
- chonus
16 Oct 2016 14:49
Hey guys, my daily was in the garage when matthew came to visit. Was on side stand and water went right up to the lowest float bowl. I already changed the oil and started it. It ran well. My question is, what else should i be looking at as far as saltwater intrusion. I have a new chain and sprockets already but am worried about bearings. I gave the bike a thorough rinse as soon as i could
-Dave
'82 kz305 lil bob
'82 kz1000 streetfighter project
'80 kz750/4 LTD
'02 kx125
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
Re: 1980 kz750 h1 hurricane matthew damage
16 Oct 2016 14:56
Wheel and swingarm bearings. It might be prudent to disassemble and clean starter. Some fresh grease on the bushings, too.
If there was water in the crankcase, I'd be tempted to do another oil change soon.
That really bites.
That really bites.
- chonus
16 Oct 2016 16:24
So i know the swingarm bearings arent sealed but arent the wheel bearings sealed? And there was zero water in the oil.
-Dave
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
- missionkz
16 Oct 2016 16:53
Iif most of the electrics were out of the brackish water, I'd rinse it off, pull the starter and wash it out, change the oil, fresh gas and ride this piss out of it.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
16 Oct 2016 17:58
Typically the wheel bearings are sealed, but water could get past them and may be lurking inside the wheel just waiting to cause problems, and I'm not sore the bearing seals were designed for extended underwater duty.
16 Oct 2016 19:33
It would be prudent to at least check and grease them. I got new ones, big difference.
- chonus
16 Oct 2016 19:59
Ok. Thanks guys. Ths whole situation has been a punch in the nads. My whole kitchen is in my garage. It takes a solid minute to get to tje toolbox. A few bearings are probably cheap insurance.
-Dave
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
'82 kz305 lil bob
'80 kz750/4 LTD
'02 kx125
16 Oct 2016 20:46
If you can get at the bearings a small xacto blade can be used to remove the bearing seal, and then you can repack them. Marine grease works well.
