Advanced Search
Search Results (Searched for: gs swing arm)
Replied by Wookie58 on topic Information on This Custom Cafe Racer Frame
31 Oct 2024 09:13
Wookie58's Avatar Wookie58
I hope you receive the feedback you get here in the "supportive" vein it is intended. The more I look at this the more potential issues I see, "custom" frames are great to set your bike apart from the crowd "if they are done right" if not you will likely end up with an evil handling little monster that will try and kill you at every opportunity (I suspect there may be a reason why this came as a "box of bits")  a couple of things worth checking out
  • Swingarm pivot location looks wrong (too high)
  • Swingarm pivot mounts look flimsy
  • Front wheel looks like it may foul when suspension is compressed
  • Rear wheel looks like it may foul when suspension is compressed
Replied by Nessism on topic Hello everyone!
21 Oct 2024 07:51
Nessism's Avatar Nessism
Good bang for the buck upgrades...
High quality shocks
PTFE brake lines
High quality tires
Download or purchase the factory Kawasaki manual for your bike, and do EVERYTHING.  Some worthwhile tasks, that most people don't do, include greasing the steering head bearings (replace them if your bike has loose ball, get tapered roller), and grease the swingarm bearings.  Some people like electronic ignition upgrade, although points are tried and true.
Check my signature and read through the "new owner things to know" thread.
Good luck
Replied by Wookie58 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
21 Oct 2024 00:48
300,000 Views..
Wow !
The bike is a stunner that's for sure, I suspect the swingarm and front end reference in the title makes it a firm favorite in the "search bar"
Replied by tk11b40 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
20 Oct 2024 22:14
tk11b40's Avatar tk11b40
300,000 Views..
Wow !
Mepb750's Avatar Mepb750
Hi,
Currently figuring out how to attach Suzuki GS750 VM26's to a Zephyr 750 head.
Have the Z900/1000 rubber carb manifold's, elongated holes, bolts straight on.
Suzuki throttle bracket looks similar to Z900 and overlaps the rear cam tunnel bolt.
Bought a Z650 (KZ650) throttle bracket, it fits around the rear cam tunnel bolt.
Sure this has been done before and found a thread about it, but the actual question is about which cables/throttle tube to use, cannot find a clear example. At the moment I have 80's GPZ750 unitrac cables and throttle tube.
My bike is in the avatar , its a bit of a bitsa, 1979 Z650 frame, JMC chrome swingarm, later gpx600 forks, re worked micron fork brace, GPZ750 wheels.
Engine currently in bits, early 80's KZ750 cases (actually fits my frame, GPZ unitrac motor that came with bike had be bogged in) , GPZ750 barrels, 90's Zephyr 750 head.
My 80's GPZ750 unitrac engine needed a lot of cylinder head work, but luckily I found a Zephyr head that has been reconditioned, stripped it anyway and its all good for less than the price of a new set of valves and it has the Z900 look, will have to file the square fin profile to something more rounded , think it will look more at home in the Z650.
Question 2, I have read something about cam circles being different in some engines, so what do I check to determine if my GPZ unitrac cams will work correctly in my Zephyr head, it has same cam cover style as the Z900's.
Have added a few pictures below.
Replied by Nebr_Rex on topic kz750 swinging arm - will it fit a kz440ltd frame?
05 Oct 2024 07:20
Nebr_Rex's Avatar Nebr_Rex
KZ400 and KZ440 are a direct swap, KZ440 being longer.
Kz550 is wider, but not by much. I narrowed one down for my KZ400.
This also upgraded the KZ400 swing arm bushings to KZ550 double roller bearings.
KZ650/750 are wider yet.
Replied by SWest on topic kz750 swinging arm - will it fit a kz440ltd frame?
04 Oct 2024 07:57
SWest's Avatar SWest
I like the drum brake. The front takes a few revolutions to grab when it rains or just gets wet. The drum always works. When I switched to mags I looked for a rear drum brake. My Lester's had it but now I have tubeless in the rear with the KZ750G rims. PITA to change tires until I got a bead braker and now I don't have to deal with rim locks. All around a much better setup.
KZ650 Swingarm? I don't need it! was created by z1kzonly
25 Sep 2024 08:34
z1kzonly's Avatar z1kzonly
OK! Marty in Buffalo is getting old!  "CRS/Biden Brain"  . I had this swing arm sitting for a year! From a parts lot. All this time? I thought it was a Z1 drum brake swing arm!!
Never measured the rear axle opening. it's 17mm.
I just painted it with single stage urethane gloss black, was going to list on ebay with re-plated hardware.
It's for sale now!  Double needle bearings with full length sleeve 16mm pivot. No axle.
(Don't laugh Clay)       I'll send you the Z1 zinc hardware!
Marty in Buffalo
Gpz1100 1983 was created by banit
07 Sep 2024 08:04
banit's Avatar banit
Hello folks
hope you are all having a good weekend.
Question for any of you builders
Starting a complete makeover on my old gpz
Love air cooled  4's
this has cosworth pistons falcon crank and h beam rods. Ape cams and rs flat slides.
Going to remove all suspension and wheels
Swap to gsxr750 shocks front wheel gsxr1000 swingarm and gsxr750 rear wheel.
Question comes from my goal to use a k&n Superbike black bar.
Top clamp I machined smooth and mounted 7/8 bar mounts .
Do any of you see any issue with a bar on this heavy weight
Thank you
1982 GPz750 r1 carburettor spacing was created by @Martingg58
31 Aug 2024 01:02
@Martingg58's Avatar @Martingg58
Hi I am new to this forum and from the UK but not stranger to working on and modify bikes. Just taken on a 1982 Kawasaki GPz750 r1 twin shock . This has been modified with a Suzuki GSX front and rear end coupled to a period brace alloy swing arm.One of the many jobs that need sorting is the carburettors. The bank that came with the bike are wrong and bodged/damaged to fit 36mm choke Keihin CV,s.  They should be 34,s. I am struggling to find a suitable bank. The spacing centre to centre on the inlet port on the barrels are. between 1 & 2 is 76mm 2 & 3 is 95mm 3 & 4 is 75mm with the distance centre to centre between 1 & 4 is 245mm . Can any one help in advice to source the correct carb’s.All the banks I have looked at on eBay don’t seem to match the spacing I need I thought I saw something on this forum but can’t find it again.
Displaying 61 - 70 out of 7254 results.
