1982 GPz750 r1 carburettor spacing
- @Martingg58
31 Aug 2024 01:02
Hi I am new to this forum and from the UK but not stranger to working on and modify bikes. Just taken on a 1982 Kawasaki GPz750 r1 twin shock
. This has been modified with a Suzuki GSX front and rear end coupled to a period brace alloy swing arm.One of the many jobs that need sorting is the carburettors. The bank that came with the bike are wrong and bodged/damaged to fit 36mm choke Keihin CV,s. They should be 34,s. I am struggling to find a suitable bank. The spacing centre to centre on the inlet port on the barrels are. between 1 & 2 is 76mm 2 & 3 is 95mm 3 & 4 is 75mm with the distance centre to centre between 1 & 4 is 245mm
. Can any one help in advice to source the correct carb’s.All the banks I have looked at on eBay don’t seem to match the spacing I need I thought I saw something on this forum but can’t find it again.
Re: 1982 GPz750 r1 carburettor spacing
04 Sep 2024 16:23
Your bike came with Mikuni BS34 carburetors. The later year KZ1000 and 1100 bikes came with the same basic carbs, difference being some relatively minor internal differences. For a restoration project, using the airbox, etc, I'd target a set of the original carbs. For a bike running pods, for example, I'm pretty sure you could get a set of the other carbs to work effectively. Regarding spacing, I don't think you need to worry about that as long as the carbs are KZ version BS34's. Actually, that said, the GS Suzuki BS34's will have the same spacing.
