Advanced Search
Search Results (Searched for: gs swing arm)
Replied by z1kzonly on topic 76z1 swingarm swap compatibility / front end sport bike compatibility
29 Mar 2019 12:15 - 29 Mar 2019 12:16
z1kzonly's Avatar z1kzonly
What's you use plan? Drag? Cruise? High Speed? Or just to be COOL at cruise night?
Budget dictates it all of course!
Don't go too long!
Try the old Suzuki GS conversion. 160-180 tire is pushing it.
For wide. And cheap, the Kaw ZZX 600? 2004-7. Thee parts are cheap on ebay. Really easy to convert, for 2 shocks like stock
Or have custom built to your specs by "PDM"
Your opening up the worm can / rabbit hole! offsets, frame mods, etc..
Keep an offset of 5/8" at engine.
Good Luck.
Here are a few things I did over the past 10 yrs.
Replied by 650ed on topic Struts 80-83 kz440
28 Mar 2019 18:26 - 28 Mar 2019 18:27
650ed's Avatar 650ed
NewYorKZ440 wrote: .................... whats the point in just struts then, like why even bother as manufacturer ? just cheaper ?
I don't think any motorcycle manufacturer ever used struts rather than shocks. I suspect some folks use them instead of shocks because they then can mount the rear wheel very close to the fender and frame since the rear wheel will not move up and down inside the fender or frame. Of course, one big problem with struts is the fact that when going over a bump or pothole the hole bike will jump up and down rather than just the rear swingarm, and this can lead to a serious handling problem especially if hitting the bump or hole while riding around a turn. The other problem is the fact that the jolt from any bump will be transferred to the rider, so some folks using struts mount the seat on springs. If you take a look at the seat in the picture of struts I provided you will see it has springs under it. Ed
Replied by Jim369bikes on topic Kz750 E1(4) swingarm swap with ZRX1100
25 Mar 2019 08:21
Jim369bikes's Avatar Jim369bikes
I did do a search thanks, and have seen the attached thread before, but thank you for your time, although a little sarcastic.
My main issue is how to fit the swing arm into the frame as it’s width is larger. It’s only a few mm, so was looking at the different options and what bushing/seals are actually required. The pivot pin/spindle and sleeve from the kz750 could be used with replacement bearings with the required 22mm ID
Cheers jim
Replied by TexasKZ on topic Anybody know anything about this swing arm?
25 Mar 2019 06:22 - 25 Mar 2019 06:26
TexasKZ's Avatar TexasKZ
Partzilla shows the same part number on the 1982 GS1000S, 1982-1983 GS1100E, GS1100ES, and the 1983 GS750S.
Replied by Nessism on topic Anybody know anything about this swing arm?
25 Mar 2019 05:15
Nessism's Avatar Nessism
Make that 1980 - 1983 GS1100E.
Replied by baldy110 on topic Anybody know anything about this swing arm?
24 Mar 2019 20:40
baldy110's Avatar baldy110
82 Suzuki GS1100E swingarm, got one on all my KZ's. It's a nice and easy upgrade. The only issue using them is you need different shocks with a clevis on the bottom instead of eyelets.
24 Mar 2019 06:39 - 24 Mar 2019 06:40
Suzuki GS1000. It was a popular modification back in the day. I have one myself. It is lighter than the KZ swing arm. If you decide to use it, you will need to use shocks for the GS or have KZ style lower mounts installed. You will also likely need a thin shim on each side of the pivot.
Replied by Sayonara on topic Head leaking oil
24 Mar 2019 06:06
Sayonara's Avatar Sayonara
All your input its been very valuable its not the same to build a stock engine as building a HP engine, its tricky enough doing it from scratch but taking over an engine that someone else did its a different matter.
I took everything apart and I am getting c=the cases welded, then I am going to source the parts for that engine the pistons are not longer made from MTC and the rings are worn so either I go 1427 or do have custom made a set of 4 pistons and rings so I do not bore again the cylinder that will cause more heath. or high drop it to 1325I have recently acquired a z1900 engine that was set for 1200 and it has 125 psi I all 4 cylinder I am going to take the chance to fit it in the chassis and do all the prep to fire it that was I can asses any repairs needed and then I am going to fit a 1978 kz 1000 engine completely stock that I have and already did everything oem for this bike.
I am going to use to 1400 engine for a pro street build I am doing with extended swing arm and modern front end,
I keep you guys posted.
Advice on a Wheel Upgrade was created by 79MKII
10 Mar 2019 19:30 - 10 Mar 2019 19:32
79MKII's Avatar 79MKII
I'm looking for ideas on a wheel upgrade for my 79 KZ1000 MKII. I currently have a 3.5" x 18 front and a 5.5" x 17 rear. Both are stock KZ wheels that were widened. The front was an 18" from a Z1-R and the rear was a 16" LTD wheel that was widened and the diameter increased to 17". I had these done about 10 years ago and went with the 17" for a better choice of tires. I've never truly been happy with the look of the 17" rear wheel. I think it looks too small. I'll attach a pic below.
Fast forward to today and I'm planning to change things up a bit with a new, stock length swingarm and more of a sportbike style rather than the dragbike style I have now. It would be so expensive to have another wheel widened and chrome plated to match the front, so what are some other options? Modern sportbike wheels look nice but I don't want to change the forks and I want to keep the stock speedo drive etc.... I want to continue to run a 180/55 on the rear.....any ideas? Thanks
Replied by CCrosswait on topic 83 KZ1100ltd Rebuild
09 Mar 2019 07:24
CCrosswait's Avatar CCrosswait
After a bit of a delay, the powder coater came through and everything looks great.
Set off straight away after work yesterday and installed the new swing arm bearings from All Balls.
Packed the rollers full of grease and pushed the seals into place. Next to install the pivots. Had a bit of overspray in the holes which required some dremel work to remove but they went in easy enough.
Positioned the swing arm and installed the center stand. Then it was time to call it a night.
Popped the stearing bearing races into the freezer before dinner. Will get back to the build after MotoGP qualifying is done this morning.
Displaying 581 - 590 out of 7255 results.
