Anybody know anything about this swing arm?
  • PeteyChamp51
  • PeteyChamp51's Avatar Topic Author
24 Mar 2019 06:31
#800950
I recently bought an 81 KZ1000 LTD, and a whole bunch of stuff came with it. Pipes, side panels, etc.. Can anyone tell me about this swingarm? I know the stock ones are round tube, and I can’t find anything about aftermarket swing arms. Plus here’s a pic of the bike :)
  • TexasKZ
  • TexasKZ's Avatar
Re: Anybody know anything about this swing arm?
24 Mar 2019 06:39 - 24 Mar 2019 06:40
#800951
Suzuki GS1000. It was a popular modification back in the day. I have one myself. It is lighter than the KZ swing arm. If you decide to use it, you will need to use shocks for the GS or have KZ style lower mounts installed. You will also likely need a thin shim on each side of the pivot.
Last edit: 24 Mar 2019 06:40 by TexasKZ.
The following user(s) said Thank You: PeteyChamp51
  • baldy110
  • baldy110's Avatar
24 Mar 2019 20:40
#800989
82 Suzuki GS1100E swingarm, got one on all my KZ's. It's a nice and easy upgrade. The only issue using them is you need different shocks with a clevis on the bottom instead of eyelets.
  • Nessism
  • Nessism's Avatar
25 Mar 2019 05:15
#800995
Make that 1980 - 1983 GS1100E.
  • TexasKZ
  • TexasKZ's Avatar
25 Mar 2019 06:22 - 25 Mar 2019 06:26
#801000
Partzilla shows the same part number on the 1982 GS1000S, 1982-1983 GS1100E, GS1100ES, and the 1983 GS750S.
Last edit: 25 Mar 2019 06:26 by TexasKZ.
  • Nessism
  • Nessism's Avatar
25 Mar 2019 13:23 - 25 Mar 2019 15:12
#801029
All the 1100E bikes from 1980 through 1983 used an aluminum swingarm. There are minor differences between 1st gen bikes and 2nd accounting for differences in the chain guard and brake line routing is all.
The 750, 1000, and 1100 Katana's also used similar swing arms, but there aren't many of those bikes being parted.
Last edit: 25 Mar 2019 15:12 by Nessism.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
25 Mar 2019 16:44
#801045
I have always been a fan of this swingarm swap
B) B) B)
  • tomsbadkz
  • tomsbadkz's Avatar
25 Mar 2019 17:25
#801048
Isnt the Suzuki swingarm about 2" longer than the stock KZ swingarm?
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
