Advanced Search
Search Results (Searched for: gs swing arm)
Replied by Link14 on topic High speed wobble.
16 Mar 2013 16:44
Link14's Avatar Link14
Hey Duck,
Where you at in CO? I'm in Fort Collins and ride a '76 KZ900 Ltd. From my research the '76 frame was beefed up from the earlier models to help with this. I havent' had this problem, but I replaced all my wheel bearings 2 years ago during the rebuild. Also replaced the swing arm bushings with needle bearings. I had over a 1/4 inch play in the swingarm before I did that. Another culprit might be the neck bearings if they are original.
To be honest, I've been too chicken to go all out since the rebuild. Had it up to 125 on 34 east of Greeley and it was really smooth, but it felt like I was starting to lift off on the rollees so I backed down.
Let me know if you're interested in the kzride to carry the flag across CO. I'm not sure If I'm going to have to ride up to Montana or N. Dakota to get it, but once it starts moving again, I'm hoping to figure it out.
Good Luck!
Link
Replied by CrazyDuck on topic High speed wobble.
16 Mar 2013 01:48 - 16 Mar 2013 01:52
CrazyDuck's Avatar CrazyDuck
Thank you very much. Looks like I am moving a few upgrades to the do ASAP list.
I guess I need to find some good rear shocks. Mine don't have that many miles on them but I didn't really like them anyway.
Rear swing arm and brake upgrade is coming very soon. Have everything but a master cylinder and sprocket. Stupid bushings are starting to show signs of wear with not that many miles. Swing arm might be bent too.
Replied by MFolks on topic High speed wobble.
16 Mar 2013 00:51
MFolks's Avatar MFolks
I copied this from a post from Jeff Saunders (owner of Z1 enterprises)
Motorcycle Wobble/Vibration Causes
There's a LONG list of potential area that can cause this.
These are not in any particular order
Wheel bearings
Steering bearings - repack grease, check tightness
Swing arm bushings/sleeves/bearings - replace if worn, repack grease
Fork springs aging - check spring length
Unequal fork oil - if seals leak, then your damping can be ineffective
Rear shocks aging, damper leaks - if you have oil leaking from the seals, the damping is toast.
Worn Tires/Mismatched tires/tire pressures/wrong size tires
Wheel alignment - don't trust the chain adjusters - I visually align the wheels.
Bent rims/broken spokes - get the wheels off the ground and spin them - check for run out / damage
Balance the wheels- makes a big difference.
Check for wheel run out(out of round).
Tire not fully beaded(seated on the rim).
Low air pressure in either tire.
Front disc warped - check for run out(out of round)
Dragging brake pads
Steering & swing arm bearings are very common problems, but so are tire issues (pressure/mismatch) and wheel alignment.
Replied by 650ed on topic High speed wobble.
15 Mar 2013 22:39
650ed's Avatar 650ed
Here's where I would check:
1. Tires - they can look perfect and still cause a high speed wobble, also make sure tires are balanced and pressure is set according to Kawasaki spec. If tires are worn replace them. If no other action in this list eliminates wobble replace the tires even if they look ok (guess how I know!) Make sure wheels are not damaged at all.
2. Shocks - if yours are original throw them in the trash - they are shot; if they have been replaced make sure they are high quality units in good shape or else replace them.
3. Swingarm bushings - if you don't know when they were replaced you should replace them (even a little play in them goes a long way to mess up handling)
4. Steering stem bearings - if yours are original replace them with tapered roller bearings; make sure steering stem torque is in spec
5. Fork oil - if not fresh replace with Bel-Ray 15w FORK oil
6. Make sure drive chain is adjusted correctly and chain/sprockets are not worn out
7. Make sure there brake rotor(s) are not warped and dragging unevenly
Also, I would try resetting the forks to the stock height to see if that eliminates the wobble.
Replied by 531blackbanshee on topic yet another KZ1000 streetfighter build
11 Mar 2013 12:29
531blackbanshee's Avatar 531blackbanshee
glad the bushings arrived and performed as intended.
it sure looks good.
love the stance.the swingarm looks good to me.
not too long,any longer might be too long tho.
keep us posted sir.
Replied by Powerstroke_fan on topic 1980 KZ 1000 B4 LTD 1327 Build
07 Mar 2013 22:32
Powerstroke_fan's Avatar Powerstroke_fan
Attachment IMG_0406.JPG not found
And finally a pic of the swingarm after a nice paint job.
Have got the swingarm installed and the front steering stem bearing replaced, new wheel bearings installed. In the process of rebuild front forks as of now. I am working on getting the last spacers made for the rear wheel and it will be done. I still gotta get a few little things like a masterlink a few o rings and some other little stuff. but overall the build is getting alot closer to being finished.
Replied by z1kzonly on topic need help identifying
06 Mar 2013 12:30
z1kzonly's Avatar z1kzonly
floivanus wrote: something of a resemblance I suppose?
The one in your picture is chromed steel. Nice classy, aftermarket piece in the day.
The one on mine is hand fabricated aluminum / heli arc welded to shape.
Since then, cut and shaped a little more at swingarm, to let more chain oil spray on my stockings with my skirt :laugh:
Axle Help for hardtail kz 750 was created by anewmanbp
05 Mar 2013 19:09
anewmanbp's Avatar anewmanbp
I am doing a garage bob of a 1979 kz 750 twin. Most of my mechanical knowledge is electrical so there are certain things that I just dont have the answers too. I welded on a hardtail to my bike and it is looking awesome, but am having problems using the stock wheel and axle. My issue is that with the swingarm now out there is way too much space between the axle plates so the wheel slides a few inches back and forth. Anyone with help would be great? Maybe a spacer? I dont know
Replied by Dabangs on topic Quick swingarm assistance???
02 Mar 2013 11:35
Dabangs's Avatar Dabangs
wireman wrote: Sure you can run a mono shock,but theres a lot more fab work involved to make it work.
Personally Im just a :woohoo: sucker a sucker for old tech dinosaur stuff like dual shocks!
I am thinking I might agree with you, plus the guy only wants $20 for the GSXR swingarm
Replied by rslingshot on topic Quick swingarm assistance???
02 Mar 2013 09:02
rslingshot's Avatar rslingshot
The first swingarm is from a 99 gsxr 600 it would be a better fit for your kz frame, just 2 pivot bolt reducer spacers and weld some shock mounts and your good.
Displaying 2411 - 2420 out of 7260 results.
