Axle Help for hardtail kz 750
  • anewmanbp
  • anewmanbp's Avatar Topic Author
05 Mar 2013 19:09
#575494
I am doing a garage bob of a 1979 kz 750 twin. Most of my mechanical knowledge is electrical so there are certain things that I just dont have the answers too. I welded on a hardtail to my bike and it is looking awesome, but am having problems using the stock wheel and axle. My issue is that with the swingarm now out there is way too much space between the axle plates so the wheel slides a few inches back and forth. Anyone with help would be great? Maybe a spacer? I dont know
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Axle Help for hardtail kz 750
05 Mar 2013 19:11
#575495
sounds like new wider axle,and custom spacer time.
line up the front and rear sprockets (a string works for a straight edge,or laser) and measure what spacers you are going to need.
hth,
  • Red Good
  • Red Good's Avatar
06 Mar 2013 02:25
#575594
If it is one of ours , call the shop . If it's not one of ours and you need a hand call the shop . Should be able to walk you through it . Red
1-918-479-4200 regular days till 6 pm central .
