High speed wobble.
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: High speed wobble.
16 Mar 2013 01:57
#577151
Experienced this myself on my 74 Z1900. I would guess there is nothing wrong with your bike. This is a well documented problem. Myself, it started at around 130. Keeping in mind that it took me a awhile to reach 130 from 120. Only after I laid on the tank behind the fairing did it start climbing again towards 130. My feet where on the back pegs. Once it started I backed off slowly and let it glide down without braking. It settled down again around 120 or so. I read years later in a cycle magazine that was given to me and was from the 70's. It had a write up on the new Z1900 and mentioned the high speed wobble. It attributed it to a weak head stem design which caused flex at high speed. I wish I could find that article.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • 893cv
  • 893cv's Avatar
16 Mar 2013 02:10
#577152
Narower bars can help with this. It sounds like wind-steer to me.
1980 kz1000 LTD
1978 Z1R
  • Roadflyer
  • Roadflyer's Avatar
16 Mar 2013 12:19
#577195
My 78 Z1R front end would shake like a wet Dog at 120 mph. One time I tried to push through 120 and it just got worse, when I backed off it shook so bad it almost threw me off the bike.
I think its just the nature of the beast unless you gusset the frame.
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
  • Link14
  • Link14's Avatar
16 Mar 2013 16:44
#577228
Hey Duck,
Where you at in CO? I'm in Fort Collins and ride a '76 KZ900 Ltd. From my research the '76 frame was beefed up from the earlier models to help with this. I havent' had this problem, but I replaced all my wheel bearings 2 years ago during the rebuild. Also replaced the swing arm bushings with needle bearings. I had over a 1/4 inch play in the swingarm before I did that. Another culprit might be the neck bearings if they are original.
To be honest, I've been too chicken to go all out since the rebuild. Had it up to 125 on 34 east of Greeley and it was really smooth, but it felt like I was starting to lift off on the rollees so I backed down.
Let me know if you're interested in the kzride to carry the flag across CO. I'm not sure If I'm going to have to ride up to Montana or N. Dakota to get it, but once it starts moving again, I'm hoping to figure it out.
Good Luck!
Link
The following user(s) said Thank You: Lorcan
  • loudhvx
  • loudhvx's Avatar
16 Mar 2013 22:02
#577278
As Ed said, tires are at the top of the list, especially the rear. That's what cured it for me, and it's also mentioned in at least one constructor's book.
  • donthaveakawman
  • donthaveakawman's Avatar
16 Mar 2013 22:13
#577281
what about at 60? helmet cam?
  • CrazyDuck
  • CrazyDuck's Avatar Topic Author
17 Mar 2013 19:43
#577399
Link:
I am just north of Boulder. I might be interested but I cannot guarantee if I will be free to do it. There is a good possibility that I have the time to do it though.
donthaveakawman wrote: what about at 60? helmet cam?
It is glass smooth all the way from 0 to around 115.
Above that, it looks like this:
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
  • Kawickrice
  • Kawickrice's Avatar
17 Mar 2013 20:11 - 17 Mar 2013 20:12
#577401
On a scale of 1 to 10 what was the pucker factor?
I had a 9.9 pucker factor at 130 one time and it scared the heck out of me because it was so violent.
It will get your respect once you expierence it that is for sure
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 17 Mar 2013 20:12 by Kawickrice.
  • wireman
  • wireman's Avatar
17 Mar 2013 22:03
#577421
Try raising front end of bike back to stock level and snug up steering head bearings just to see if it helps B)
  • CrazyDuck
17 Mar 2013 23:16
#577438
Pucker factor was fairly low to be honest. It was a strange feeling but it wasn't violent. It would have been bad if I tried to push through it because it got worse the faster I went.
I set the front end back up and I am going to change to 15w fork oil on Tuesday when I can get some more. I won't be able to say if it helps for a while as I rarely do speed runs like that. I am more into scraping foot pegs through the twisties however I don't like losing to a Ninja 500!
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
  • donthaveakawman
17 Mar 2013 23:42
#577444
a steering damper wouldn't hurt but it is still an issue nonetheless.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
18 Mar 2013 10:16
#577482
wireman wrote: Try raising front end of bike back to stock level and snug up steering head bearings just to see if it helps B)
+1
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
